  • June 21, 2025, 06:33:17 PM
Author Topic: Carbon Props  (Read 1704 times)
Offline James Mills
Carbon Props
« on: October 10, 2006, 10:04:00 PM »
Is there a reason why we don't see more painted carbon props on our stunt ships (seems like it would have a safety benefit as well as appearance).
James
AMA 491167
Re: Carbon Props
« Reply #1 on: October 11, 2006, 06:47:47 AM »
H iJAmes,
Really good question......... I believe it might just be laziness!  With the repitching that often goes on, maybe the thought is that the paint job would get messed up.  ???
Don't really know why I don't paint ours!
Bill <><
Offline Joe Gilbert
Re: Carbon Props
« Reply #2 on: October 11, 2006, 07:09:01 AM »
For me it is a balance problem. It is a pain to  balance them after painting them.
Joe Gilbert
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Carbon Props
« Reply #3 on: October 11, 2006, 11:16:50 AM »
After getting nailed by the one on my Legacy I painted the tips white, does that count  ;D
Offline Tom Perry
Re: Carbon Props
« Reply #4 on: October 11, 2006, 11:22:57 AM »
Probably shows up a lot better than the blood red you first painted it with.   y1
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Jim Pollock
Re: Carbon Props
« Reply #5 on: October 11, 2006, 06:35:52 PM »
I think that you should paint the last 1/4" of a carbon prop white or yellow before you balance it and then just leave the very tip alone while you use the rest of the blades for balancing...
Couldn't hurt anyting, could it???
Jim Pollock
Re: Carbon Props
« Reply #6 on: October 11, 2006, 11:22:14 PM »
Good suggestion.  I'll paint the prop tips.  A prop took a nip out of my shirt the other day, reminding me to be a little more careful.
Offline Richard Grogan
Re: Carbon Props
« Reply #7 on: October 12, 2006, 10:40:45 AM »
Jim Pollock
RIGHT ON x:            !!!!
Tip Front AND BACK!!!
Long Live the CL Crowd!
                  AMA 85745
Offline Tom Perry
Re: Carbon Props
« Reply #8 on: October 12, 2006, 11:33:13 AM »
Jim Pollock
Or even better yet balance the prop then paint it while on the prop balancer.  If one end is a little too heavy add a little more paint to the other end.
 y1
Tight lines,
Tom Perry
 Norfolk, Virginia
