  • July 17, 2025, 02:29:17 PM
Author Topic: KA Series  (Read 29473 times)
Re: KA Series
« Reply #50 on: August 05, 2016, 05:59:18 AM »
 Tom Dixon did his plans from photos of the KA-10. He never had the original plane in his hand. He got quite close considering how he did it.
I talked to Tom when he first brought the model to a contest and used it that day. He didn't stay with it for long.
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #51 on: August 09, 2016, 03:24:17 PM »
I like the lines also but, I would want to put my aerodynamics AND force arrangements on it too.
That's exactly what I did.
Here's my lookalike at the 2016 WCh in Australia:
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #52 on: August 09, 2016, 04:25:20 PM »
 Unless I am mistaken and I could be, there was a KA6, KA8 and a KA10 and I think they were all designed originally by Anatoly Kolsenikov.  Then Yatsenko did one very similar that he called the CLASSIC in F2B.  I think I have my facts straight.  Thanks for everyones input so far.
The Classic next to my KA-10 lookalike that has been made partly of a KA-8 plan with russian text. I have no idea where it came from, too long ago since I got it.
Took ~1/2" of the top of the fin to make it look 'right'. Had to shorten the nose for the heavier motor. Simplified the three scoop air intake to one with roughly the same outer dimensions. Extendeded the landing gear to accomodate 13+ diam. props.
Being based on another non in line design, the wing sits lower in the fuse. But I'm happy, it's my best plane ever.
Compare my 2016 lookalike to the original in France 1990. For sure the american plan is way off, just as mine is.
So I'd strongly advice against using this to create a 'real' KA-10.
Re: KA Series
« Reply #53 on: August 09, 2016, 07:17:29 PM »
It looks like someone has a REAL KA 8 plan There , Then .  ;D ;)
Offline Mike Griffin
Re: KA Series
« Reply #54 on: August 09, 2016, 09:39:26 PM »
I want to thank everyone for all the contributions in this thread.  This information has moved the possibilities of an enhanced KA10 kit more feasible for the near future.  It has revised a lot of interest in the series and I do have several people who have contacted me for a kit if we proceed with the project.  Thank you again for all the input.
Re: KA Series
« Reply #55 on: August 11, 2016, 03:22:16 PM »
I started a build today on the KA10 and will be powering it with a ST.51.  If this is a successful flyer, I plan on building the smaller KA5 and putting a ST.46 on it.  I have been talking with Eric Rule about the possibility of a lazer cut kit down the road.
even though I'm not flying control line anymore - if you kit the KA10  - i'll take one
Re: KA Series
« Reply #56 on: August 11, 2016, 10:27:04 PM »
thank you Wynn.  We are very close to having enough commitments.  Only 3 more commitments needed.
Re: KA Series
« Reply #57 on: August 13, 2016, 02:32:11 PM »
Wynn it looks like we are getting really close to making this kit a reality.  I will PM you with details.
Re: KA Series
« Reply #58 on: August 15, 2016, 09:11:28 AM »
I personally think this kit needed someone to do a built up wing version.
Milton the kit we are doing has a built up wing.  Eric Rule at RSM is drawing it in CAD as we speak
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #59 on: August 20, 2016, 07:17:23 AM »
Not really, just a few pictures from the plan and two 1:1 A4 copies of the canopy area.
For me enough to reconstruct to a level I was happy with, judge for yourself when looking at my photo.
I think I got closer in looks than the american existing plan. That is further off, IMO.
Another point: the KA-8 and -10 are NOT in line designs, close, but not entirely.
The motor and stab are, but the wing is (if I remember correctly)~ 8mm below the center line.
As you can see on my plan, I took some off of the fin, looked more balanced on my model.
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #60 on: August 21, 2016, 01:26:30 PM »
I think this is the nicest, somewhat happier colours after cccp collapsed.
I have seen this model somewhere lately but I can't get the name or location of current owner in my head. Propably in Kiev.
This picture was taken at the W. Ch. 2008 in France. I remember so well, because it was such a disastrous championship for me.
The pilot was a young man from Kazachstan.
Re: KA Series
« Reply #61 on: August 21, 2016, 07:46:32 PM »
Looksa like the PLAN here : http://modellflygnytt.se/gamla/1997/Lina_1997-1.pdf for the Undercarrage .  LL~ >:D
also a good side shot KA10 1996 ?
Offline RogerGreene
Re: KA Series
« Reply #62 on: August 24, 2016, 07:33:39 AM »
Just wondering about this.
It seems that the Russian KA Series planes have engine, wing and stab/elev all in line in these photos. What advantage is this over the standard "Nobler" setup?
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #63 on: August 24, 2016, 10:23:07 AM »
Roger
In line? ::) Did you read this?>> http://stunthanger.com/smf/open-forum/ka-series/msg458333/#msg458333
Many models with motor, wing and stab not in line are flying extremely neutral. It's all about balance.
In line is another way to achieve this. My lookalike is not an inline and flies neutral.
Here's the man, Gerard Billon, who explained (he took the measurements) to me that the KA-10 is not entirely in line.
A model built by Anatoli, specially for him. In Frech colors! ;D
« Last Edit: August 24, 2016, 10:46:38 AM by NED-088 »
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #64 on: August 24, 2016, 11:20:10 AM »
Another original!
Offline RogerGreene
Re: KA Series
« Reply #65 on: August 24, 2016, 12:52:18 PM »
I have been looking at the three views on the F2B Mace R-2 Shark and the KA10 from Model Aviation. Thanks Ned-088, also saw the photo above of the fuselage elevation/section. 8mm...5/16".
Thanks.
Fly Stunt <><
AMA 435R
Offline Michael Palm
Re: KA Series
« Reply #66 on: January 02, 2017, 05:30:29 PM »
The straight back end of the fin, on the Dixon plan and Mike Griffins kit, where did it come from. The pictures I have seen of Kolesnikovs planes, its always have a slight forward leanig from bottom to the top.
R/C is disco, C/L is Rock n Roll
Re: KA Series
« Reply #67 on: April 15, 2018, 06:56:58 PM »
http://forum.rcdesign.ru/f95/thread509658.html
just found this . Theres a Traslate thing there . or up to the left on the mouse posn. Or Something .
sortoff a bitoffa detailed ?? History . Photographically anyway .
K - 51 Engine, it says .
a few whys and wherfores there, anyway. Dosnt seem bugged .
Offline chen chien lung
Re: KA Series
« Reply #68 on: September 26, 2019, 07:17:20 PM »
Hi! Friend, this is my 2016 WC in Australia.
A photo taken for you.
Offline NED-088
    • Heartstrings
Re: KA Series
« Reply #69 on: September 30, 2019, 03:18:59 AM »
Thank you! :D
This was probably my last WCh.
I'm still flying F2B, but don't pursue a competitive career, one must know when it's time.... ;)
Re: KA Series
« Reply #70 on: September 30, 2019, 07:17:54 PM »
Thank you! :D
Dear Friend
Able to participate in WCH
For the model player, it is already a dream.
We like to fly, not just for competition
Because we really like this sport. ;) :) :)
