  • June 25, 2025, 03:36:28 PM
Author Topic: Thinning Super Fil  (Read 1344 times)
Offline Mike Griffin
Thinning Super Fil
« on: January 02, 2023, 01:41:53 PM »
After mixing the two components I find that the mixture may be a little thick.  What have you all used to thin it?
Offline Jim Svitko
Re: Thinning Super Fil
« Reply #1 on: January 02, 2023, 02:49:14 PM »
I found that wetting it with MEK substitute will help it spread easier.   There might be other products that work as well but I have only used the MEK substitute.
Offline Walter Hicks
« Reply #2 on: January 02, 2023, 04:06:58 PM »
An expert finisher advised me to use Lacquer thinner and it indeed works very well . Test the amount on practice pieces as to how much you thin it
Much easier to use when thinned.
« Reply #3 on: January 02, 2023, 05:46:37 PM »
I have used Alchohol since it is or at least acts like an epoxy.  I used it to wet my fingers to smooth fillets and discovered that it was a good thinner as well.  Doesn't take much.  Side + is that a bit thinner it is also a bit sticker.
« Reply #4 on: January 02, 2023, 07:31:58 PM »
   Make sure it is anhydrous/99%, because you do not want to trap water in it. Lacquer thinner or acetone seems a lot safer, although I haven't ever tried to thin it with anything.
« Reply #5 on: January 02, 2023, 07:38:32 PM »
I never use anything but 99%.  It only takes a couple of drops to make it stick easier and flow.  Doesn't seem to have any affect on drying time.  The other thinners mentioned are probably better, but I have limits on what I can store in my office/shop.  I can get away with alcohol!
« Reply #6 on: January 02, 2023, 09:20:29 PM »
Epoxy reducer works very well.
« Last Edit: January 03, 2023, 07:54:26 AM by Trostle »
Online Perry Rose
« Reply #7 on: January 03, 2023, 05:25:48 AM »
I mix it in a two ounce cup. If it needs thinning I warm it by floating the cup in hot water or a few seconds in the micro wave. It cures slow enough to not be a problem.
