General control line discussion => Open Forum => Topic started by: Mike Griffin on January 02, 2023, 01:41:53 PM
After mixing the two components I find that the mixture may be a little thick. What have you all used to thin it?
I found that wetting it with MEK substitute will help it spread easier. There might be other products that work as well but I have only used the MEK substitute.
An expert finisher advised me to use Lacquer thinner and it indeed works very well . Test the amount on practice pieces as to how much you thin it
Much easier to use when thinned.
I have used Alchohol since it is or at least acts like an epoxy. I used it to wet my fingers to smooth fillets and discovered that it was a good thinner as well. Doesn't take much. Side + is that a bit thinner it is also a bit sticker.
Make sure it is anhydrous/99%, because you do not want to trap water in it. Lacquer thinner or acetone seems a lot safer, although I haven't ever tried to thin it with anything.
I never use anything but 99%. It only takes a couple of drops to make it stick easier and flow. Doesn't seem to have any affect on drying time. The other thinners mentioned are probably better, but I have limits on what I can store in my office/shop. I can get away with alcohol!
Epoxy reducer works very well.
I mix it in a two ounce cup. If it needs thinning I warm it by floating the cup in hot water or a few seconds in the micro wave. It cures slow enough to not be a problem.
