Hi Mike,
To make a long story short, no it's to easy with dope. I've used finishing resin before but it smell worse than dope. Also, if you are trying to not use dope at all, then use finishing epoxy brushed on the surface then wipe off as much epoxy as you can. Then place C/M on the surface and smooth out the Matt. When dry, brush on a coat of clear Superpoxey clear (or the equivalent) and let dry. Sand with 220 grit sandpaper which gives you a wonderful surface to start the painting.
Another option is to use Superpoxy clear on the surface, add .5 glass cloth, place a layer of cling wrap over the glass and squeeze out the excess epoxy and allow to cure (2 days). I've used this method many times on racing models, team race, goodyear, rats, fuse, flaps and elevators on stunt models. You will find this method leaves a glass smooth shiny surface. Standoff the shine with 360 grit sandpaper prime & paint from there. This does take a little skill to get it perfect but I nailed it the first time and have used this method many times.
Later,
Mikey
