  • July 16, 2025, 11:13:13 AM
Author Topic: Custom Metal Venturi  (Read 2165 times)
Offline Bill Sawyer
« on: December 23, 2010, 12:16:06 AM »
I know several people make venturi out of delrin or other plastic type material but I would like to get some metal ones - just because I like the looks. Does anyone make these to order if I supply the measurements?
Bill Sawyer
AMA 53987
Windancer Models
Re: Custom Metal Venturi
« Reply #1 on: December 23, 2010, 12:23:17 AM »
Hi Bill,
I have gotten metal venturi from Randy Smith, Leonard Neumann, Jim lee, and Byron Barker over the years.  Most use delrin for ease and cost, I *think*.
Probably anyone who makes then would do them in metal but they will cost more, I'm sure.  AS to ones who "only" use metal, I don't know.
Merry Christmas!
« Reply #2 on: December 23, 2010, 04:39:05 AM »
I made one for an OSFP .15 once outta the end of my exact-o knife. Did it in my drill press. A drill press is just a vertical lathe LL~ ;D
Dwayne
« Reply #3 on: December 23, 2010, 05:34:39 AM »
I've used a piece of brass pipe with 3/8 OD and 9/32(or .281) ID I put it in a drill and filed part of it to fit the engine then flared the other end with a dremil.
Offline Pat Johnston
« Reply #4 on: December 23, 2010, 05:58:32 AM »
Heck, I've made venturis out of Maple.  Works fine, as the venturi is just a means of metering the airflow.  Did use the "vertical lathe" or Drill Press to you, John.  How's that for thinking totally outside the box?
Pat Johnston
Hillbilly Engineering
Skunk Works
Dwayne
« Reply #5 on: December 23, 2010, 06:24:59 AM »
Pat Johnston
Skunk Works
I think we may be hyjacking this post but did you coat the wood with anything?
Bill, Leonard over at SSW makes custom metal venturis.
Online john e. holliday
« Reply #6 on: December 23, 2010, 09:46:50 AM »
I guess I am partial, but have several of Jim Lee's venturi's of different sizes for my LA engines.  Even have a thrust washer for Green Head K&B .35 Jim did for me.   H^^
Offline Bill Morell
« Reply #7 on: December 23, 2010, 01:28:48 PM »
Scott Riese makes some of the best alloy venturi's available.
Bill Morell
Vietnam 72-73
Offline phil myers
« Reply #8 on: December 23, 2010, 01:38:11 PM »
Do any of these guys accept paypal (I'm in the UK) for payment as I need one for my os 35s. I don't mind if its plastic or metal just as long as it includes the NVA
Phil
