  • July 27, 2025, 11:49:22 PM
Author Topic: Adhesive removal from wing  (Read 1199 times)
Offline James Mills
« on: May 19, 2007, 09:23:40 PM »
I tried using shelf paper for the lettering and numbers for my new plane.  The lettering came out decent but I'm having trouble getting the adhesive from the paper off the wing.  I've tried glass cleaner and alcohol and am not having much luck.  Any ideas?
James
Should have mentioned that it was a dope finish.
James
Thanks for the tip, the goo gone worked.
James
« Last Edit: May 20, 2007, 07:15:59 PM by James Mills »
AMA 491167
Offline Leester
Re: Adhesive removal from wing
« Reply #1 on: May 19, 2007, 09:27:59 PM »
What is the wing finished with? If it's $kote or similar acetone should do it, but if it's painted I don't know.
Leester
ama 830538
Offline Keith Spriggs
    • khspriggs
« Reply #2 on: May 19, 2007, 10:20:43 PM »
They make specific cleaner for adhesive removal. You might check with a large home center or, office supply store. They also make a product that is sold at auto paint stores for removing stripes and that type of thing. With any of them check in an inconspicuous spot. Here is a link to some home remedies.
http://www.doityourself.com/stry/stickyfaq
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: May 20, 2007, 06:10:36 AM »
Goo-Gone?
--Ray
AMA902472
