  • June 14, 2025, 10:29:59 PM
Author Topic: 4-40 threaded clevis  (Read 1550 times)
Offline Mike Griffin
« on: January 15, 2024, 04:21:02 PM »
I am having one heck of a time trying to find 4-40 threaded clevis.  Sullivan used to sell them 12 in a pack but I cannot find them on line anywhere.  Anyone know where I could find them?
Offline Frank Imbriaco
Re: 4-40 threaded clevis
« Reply #1 on: January 15, 2024, 04:43:04 PM »
You can buy Sullivan Products direct. I recently bought some RC pushrods and the shipping cost was very fair.
Offline Jim Svitko
« Reply #2 on: January 15, 2024, 04:48:21 PM »
Would something like this work for you?
I have these made for me, either 4-40 thread or 3mm X .5mm pitch.  I insert a section of 1/8 OD brass tubing into each lug for a bushing since I use 3/32 music wire for the pinned joint.
« Reply #3 on: January 15, 2024, 04:52:18 PM »
Hi Jim,
If it is for a 4-40 thread, yes it would.  What do you use as a retaining pin to secure the clevis?
« Reply #4 on: January 15, 2024, 04:53:49 PM »
Frank, I went to their website and unless I missed it, I could not find the packs of individually packed clevis.  I saw pushrods with a clevis on them but no individual packs of just clevis.
Offline Jim Svitko
« Reply #5 on: January 15, 2024, 04:57:56 PM »
Not a real good photo here but I hope it helps.  This clevis is very generic but I suppose it can be modified for specific situations.  My horns are made with an upright and bushing to match the clevis internal width.  I use a 3/32 wire as the pin.  One end of the pin is bent over slightly and a wheel collar on the other end.
« Reply #6 on: January 15, 2024, 05:08:03 PM »
  I think the best 4-40 clevis that were available were the plated ones by Great Planes, but are not available any longer. I never had a problem with one of those on a .46 size mode or smaller.  I have seen and experienced Du-Bro clevises breaking from vibration and I think the plating on the Great Planes units gave them more strength.
« Reply #7 on: January 15, 2024, 06:30:54 PM »
I could see how it was attached.  Where do you buy these Jim?
« Reply #8 on: January 15, 2024, 06:32:35 PM »
Those are the ones I used to use as well Dan.  Seems like a lot of these smaller items are getting harder and harder to find.
Offline John Paris
« Reply #9 on: January 15, 2024, 07:31:48 PM »
Mike,
Dubro makes something called a safety lock clevis that is plastic and has served me well over time.  I do not recall seeing anything bad on these over the years but they are a little wide to fit in the back of some airplanes.  Below is a link to some available from Tower.
https://www.towerhobbies.com/product/safety-lock-kwik-link-4-40/DUB817.html?gad_source=1&gclid=EAIaIQobChMIpqi7ge7ggwMVak1HAR1BwAN7EAQYAyABEgI7cPD_BwE
John Paris
269
« Reply #10 on: January 15, 2024, 09:47:22 PM »
Mike,
I have used these on three planes with zero issues where I did not have room for a ball link.  Just be careful to get the clip locked and in it's tracks and make sure you have bushed the horn with tubing that fits that tiny pin or you will get the dreaded "slop"
« Last Edit: January 15, 2024, 10:28:59 PM by Ken Culbertson »
Online Reptoid
« Reply #11 on: January 16, 2024, 01:14:41 AM »
       Don
       AMA # 3882
