  • July 18, 2025, 03:32:37 PM
Author Topic: Is this real?  (Read 1737 times)
Is this real?
« on: May 08, 2022, 06:34:01 AM »
If this is not an ad for spectra than we are screwed.
https://sullivanproducts.com/product/seven-strand-ss-018-wire-2-70-lines/
« Last Edit: May 08, 2022, 02:10:15 PM by Ken Culbertson »
Teodorico Terry
Re: Is this real?
« Reply #1 on: May 08, 2022, 06:58:53 AM »
I guess that makes Brodak's prices look reasonable...That price is carzy.
Re: Is this real?
« Reply #2 on: May 08, 2022, 07:13:45 AM »
Lines prices are getting out of hand. Spectra - FINS 40G are stronger, thinner, lighter, available at local fishing outlets or online and cost lots less. Available in several LB tests that fit our needs.
https://www.finsfishing.com/FINS40G-p/fns40g.htm
I've been using the 45LB test for 35 size ships and they are great, no noticeable, stretch and very durable.
Best,   DennisT
Re: Is this real?
« Reply #3 on: May 08, 2022, 09:03:08 AM »
With control lines, as with a lot of other things, modelers buy whatever falls off the truck from other industries.  As near as I can tell, that "other industry" for us is fishing line, although there may be some industrial use for itty bitty stainless cable.  As such, if that industry goes to some other technology, or moves offshore, then we're left hanging (this is basically what happened with nitromethane -- it's used in a lot of industrial processes that aren't done here anymore).
So I checked a couple of fishing sites -- prices on 7-strand stainless steel leader wire doesn't seem to have gone up too much.  At least -- not enough to justify Sullivan's price increase.  They've probably identified that as a slow item, and are raising prices to discourage sales -- or something.
Talk to Melvin Shute, MBS model supply.  You can get yourself 1000' of the line size of your choice plus crimp sleeves (if you want 'em), eyelets, and probably a crimp tool, for not much more than that one set of lines from Sulivan.
I find it much more convenient to just make up a set of lines off of a big real than to use a line set.
Sig, BTW, sells their version of that same line set for $25.
Re: Is this real?
« Reply #4 on: May 08, 2022, 11:40:33 AM »
Best,   DennisT
I have a 65LB spool of each sitting on my desk waiting for a Boy Scout to come by and tie them.  When my Ukraine lines ware out it will be "Spectra".
Re: Is this real?
« Reply #5 on: May 08, 2022, 12:43:03 PM »
I found a set of SS lines I made in 2005 and used for several years. If I cut off the ends and make new ends would they be just as safe as new lines?
Offline Jim Svitko
Re: Is this real?
« Reply #6 on: May 08, 2022, 12:55:32 PM »
Probably so, unless you can see/feel damage, such as frayed strands.  If in doubt, a pull test can put your mind at ease.
Offline Istvan Travnik
Re: Is this real?
« Reply #7 on: May 08, 2022, 03:25:27 PM »
In the ancient times I observed (and then measured, as well) that the SIG lines are significantly weaker than Sullivan products.
It was so surprising, but since that ( ca. 40 years) I always avoid SIG lines.
Does somebody know what is the situation now?
(I broke some lines in laboratory, and Sullivan 7 strand .015 was right 20N strong, and the stongest was some Russian, or Ukrainian, maybe Soviet 7-strand .015" with 24N strength. Sorrowfully, after some years the bronze (or brass) coating weared, and some rust appeared. :(
Istvan
Offline pmackenzie
  • Pat MacKenzie
Re: Is this real?
« Reply #8 on: May 08, 2022, 04:04:35 PM »
1000' of .018 is $40 at MBS.
https://mbsmodelsupply.com/
(click on the catalog button to see the price list)
MAAC 8177
Offline Peter in Fairfax, VA
Re: Is this real?
« Reply #9 on: May 08, 2022, 04:30:02 PM »
Kinks are the worst.  While my circa 1975 Green Box Nobler / Fox 35 flew its best on kinked .012 lines, the kinks brought it to its demise.
As others say, get a 1000' spool from MBS in whatever sizes you favor - .018, .015, .012 in my case.
Re: Is this real?
« Reply #10 on: May 08, 2022, 04:49:10 PM »
Dear Pat,
Do you know some info on MBSmodellsupply lines? How many strands have they? 4? 5? 7? or 19?
Thanks in advance: Istvan
Offline pmackenzie
  • Pat MacKenzie
Re: Is this real?
« Reply #11 on: May 08, 2022, 04:52:41 PM »
Dear Pat,
Pretty sure it is 7 strand, same as Sig and Sullivan.
MAAC 8177
Re: Is this real?
« Reply #12 on: May 09, 2022, 08:24:06 AM »
Pretty sure it (MBS control line cable) is 7 strand, same as Sig and Sullivan.
Yes it is.  It looks like exactly the same stuff.
