There are two articles on the Fancherized Twister and one article on the "Armourized" Top Flite Tutor. I have all three articles plus the plans CAD drawn by Bob Kruger, on one file. The drawing was done with heavy involvement of Ted Fancher and he himself said that they are indeed the defintive plan. I am very pleased to have this complete set for myself and any others that are contemplating building one.
Glenn;
Actually, there is one discrepency.
When I did the plans many years ago, what I went by was a copy of a copy of a copy of a copy of a.... (you get it) of the article. My original 'Model Aviation' mag that had the details and pictures had long been lost in one of the many moves I had back when I was in the Army. The actual pictures of the FT were somewhat garbled. I could figure everything out except the rudder shape, which I had to approximate as best I could. After consulting with some fellow flyers who still had the original mag, I realized my "rake" on the LE of the rudder was greater than Ted's. I querried Ted and asked if I should change it, his words were "leave it, it looks better than what I came up with."
The rest is as Ted described in his article.
Regardless, its a great flying ship.
Just one note - and some will disagree with me on this. The wing as designed benefits from a doped finish, e.g. it needs the resistance to tension that doped silkspan or silk provides. Monocoat (and other plastic coatings) are wonderfully tough, but they do stretch a little when under load, albeit they return to their original state once the load is removed. I had a box stock Twister wing fail once just from flexxing after about fifty flights, and it was not due to shoddy construction... :-) I could actually feel the wing "flexxing" during flight. If you use plastic film covering on this wing, I strongly suggest some additional bracing between ribs along the spars to reduce the flex.
I have also built the Twister wing with a C-Tube construction method, e.g. 1/4" spars top and bottom, 1/4" square LE, with sheeting and capstrips. That will compensate for the slight stretch of film coverings. If you want a .pdf of it, let me know.
For a sport flyer who likes to bore holes in the sky, the Twister and its derivatives is hard to beat.
Bob
