  • July 01, 2025, 03:41:40 PM
Author Topic: Screw size  (Read 1442 times)
Offline peabody
Screw size
« on: May 13, 2018, 06:34:53 AM »
Help on the screw size on Great Planes nylon spinners with aluminum backplates?
Besides the awful Phillips heads which I strip first time....I've lost one.
Online Gerald Arana
Re: Screw size
« Reply #1 on: May 13, 2018, 12:21:41 PM »
Here's what I do: Throw away those screws that come with them. Drill one of the spokes and tap it for 4-40 X 1/4" cap heads and you're ready to go.
Jerry
Offline Jim Svitko
Re: Screw size
« Reply #2 on: May 13, 2018, 03:26:49 PM »
I believe it is a 3mm and maybe a JIS for the screwdriver bit.  You can replace them with 3mm internal hex head screws if you like.
Offline Mike Haverly
Re: Screw size
« Reply #3 on: May 13, 2018, 04:28:47 PM »
You can get away with just putting a 4-40 socket head screw in the existing hole.  It is aluminum, yes it should be drilled out but a little persuasion and the 4-40 will go in.  Or use a tap on the existing hole.  Or, get a
M3 socket head cap screw from your local fastener supplier.  Microfasteners will have them as well as McMaster Carr.  There are probably more "ors" but one of the above will get the job done.
Offline peabody
Re: Screw size
« Reply #4 on: May 13, 2018, 04:46:41 PM »
I'll try the 4-40s if I have them short enough
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
Re: Screw size
« Reply #5 on: May 13, 2018, 05:29:22 PM »
 Rich:
Go to Ace Hardware with the nut or whatever & find what you need.
Offline Doug Moisuk
Re: Screw size
« Reply #6 on: May 13, 2018, 07:27:38 PM »
3mm/4/40? What's the diameter of this spinner?
Doug Moisuk
MAAC 3360L
Offline Jim Svitko
Re: Screw size
« Reply #7 on: May 13, 2018, 08:28:48 PM »
Local hobby shops should have 3mm socket head screws.  DuBro supplies them.
Offline Geoff Goodworth
Re: Screw size
« Reply #8 on: May 14, 2018, 08:41:17 AM »
I just checked one that I have. The screws are M3.
Offline Bootlegger
Re: Screw size
« Reply #9 on: May 14, 2018, 09:21:14 AM »
  Rich, I have used 4-48 screw's and they fit, try them..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline peabody
Re: Screw size
« Reply #10 on: May 14, 2018, 11:14:27 AM »
I tapped the backplate for 4/40 and used 1/4" 4-40 screws
Re: Screw size
« Reply #11 on: May 14, 2018, 05:20:23 PM »
M3's are available at most GOOD hardware stores and you won't risk screwing up your spinner!
