  • July 16, 2025, 11:50:19 PM
Author Topic: MSC  (Read 2004 times)
Offline Louis Rankin
MSC
« on: August 05, 2010, 09:16:09 PM »
The Memphis Stunt Classic (MSC) is just around the corner.  Make sure to make your reservations.  Info in the events section.
Louis Rankin
Somerville Tennessee
AMA 10859
Online Howard Rush
Re: MSC
« Reply #1 on: August 05, 2010, 10:26:24 PM »
Is that the one held high up on a ridge?
Offline Mike Keville
Re: MSC
« Reply #2 on: August 06, 2010, 06:53:27 AM »
...just a half-a-mile from the Mississippi bridge?
« Last Edit: August 06, 2010, 07:40:08 AM by Mike Keville »
Offline Ward Van Duzer
Re: MSC
« Reply #3 on: August 06, 2010, 08:11:49 AM »
Mike,
You bad!
w.
Offline Larry Fernandez
Re: MSC
« Reply #4 on: August 06, 2010, 08:23:46 AM »
Just take a message and write it on the wall.................
Larry, Buttafucco Stunt Team
Re: MSC
« Reply #5 on: August 06, 2010, 09:06:19 AM »
...more than that I cannot add.
Re: MSC
« Reply #6 on: August 06, 2010, 09:29:07 AM »
Well it is not up on a ridge. But close to the Memphis Motor Sports park where sometimes you can here the race cars burn a lot of Nitro.
It is close to the Memphis "M" bridge, but more then a 1/2 mile.
Lou has a good contest and the plaques he handed out last year were very cool. I have mine up in my office.
Re: MSC
« Reply #7 on: August 06, 2010, 10:01:48 PM »
Yeah, Paul, we know where it is.
Apparently you're unfamiliar with the classic Johnny Rivers tune that helped spawn some of the replies above --- starting with Howard's witticism.   ::)
Re: MSC
« Reply #8 on: August 06, 2010, 11:08:38 PM »
Some sources say the songwriter was Mr. Charles Berry, of St. Louis, MO.  Also known around Boeing as the innovator of using water injection for increasing power output.  H^^ Steve
http://www.lyricsdepot.com/chuck-berry/memphis-tennessee.html
Online Howard Rush
Re: MSC
« Reply #9 on: August 06, 2010, 11:22:12 PM »
Steve, it seems that you've started back doing the things you used to do.
Re: MSC
« Reply #10 on: August 07, 2010, 05:45:07 AM »
It's enough to make Beethoven roll over.
