General control line discussion => Open Forum => Topic started by: Louis Rankin on August 05, 2010, 09:16:09 PM
The Memphis Stunt Classic (MSC) is just around the corner. Make sure to make your reservations. Info in the events section.
Is that the one held high up on a ridge?
...just a half-a-mile from the Mississippi bridge?
Mike,
You bad!
w.
Just take a message and write it on the wall.................
Larry, Buttafucco Stunt Team
...more than that I cannot add.
Well it is not up on a ridge. But close to the Memphis Motor Sports park where sometimes you can here the race cars burn a lot of Nitro.
It is close to the Memphis "M" bridge, but more then a 1/2 mile.
Lou has a good contest and the plaques he handed out last year were very cool. I have mine up in my office.
Yeah, Paul, we know where it is.
Apparently you're unfamiliar with the classic Johnny Rivers tune that helped spawn some of the replies above --- starting with Howard's witticism. ::)
Some sources say the songwriter was Mr. Charles Berry, of St. Louis, MO. Also known around Boeing as the innovator of using water injection for increasing power output. H^^ Steve
http://www.lyricsdepot.com/chuck-berry/memphis-tennessee.html
Steve, it seems that you've started back doing the things you used to do.
It's enough to make Beethoven roll over.
