  • July 14, 2025, 05:53:57 PM
Author Topic: K & S Silkspan  (Read 5558 times)
Offline mike londke
K & S Silkspan
« on: May 06, 2016, 08:42:29 PM »
I WAS bidding on 14 pieces of K & S Silkspan until it hit $40, now it's over $94!!!! I knew the stuff was hard to find but jeez!  HB~> HB~> HB~>
Offline billbyles
Re: K & S Silkspan
« Reply #1 on: May 06, 2016, 09:17:32 PM »
Hey Mike, that is only $6.71 per piece...I'll sell ya a coupla sheets for only $10.00 per sheet at the "buy it now" price! y1
Bill Byles
AMA 20913
So. Cal.
Re: K & S Silkspan
« Reply #2 on: May 07, 2016, 10:03:49 AM »
I've got a box of SIG med silk span that I used a small portion of one sheet.  I think there are 10 sheets.   But before I sell it to some one with more money than  brain, it is going to my flying friend that has helped me a lot recently.   OK Dave? H^^
Re: K & S Silkspan
« Reply #3 on: May 07, 2016, 10:19:20 AM »
So very kind John.  I'll try not to use it all on one airplane.  And just as I've run out.
Offline jim welch
Re: K & S Silkspan
« Reply #4 on: May 07, 2016, 10:36:04 AM »
Mike I have K&S and sig SGM...sold 68 sheets last week from a note on here that nobody paid any attention to in the paint and finishing section so I took it down and someone bought it all from a PM afterwords...jim
AMA 89335
Re: K & S Silkspan
« Reply #5 on: May 07, 2016, 10:36:42 AM »
  I need to take inventory of what's in the basement! I may be sitting on my retirement and not know it! And that doesn't include what is included in the kits I have stashed! What I don't have extra off is spare time!
  Dan "Going out to try and clean the garage" McEntee
Offline mike londke
Re: K & S Silkspan
« Reply #6 on: May 07, 2016, 11:57:21 AM »
Darn Jim! I never saw it. I would have cleaned you out!
Re: K & S Silkspan
« Reply #7 on: May 07, 2016, 12:40:23 PM »
  This might be a good opportunity to review the different grades that K&S put out if anyone knows for sure what they are. GM, SGM, O,OO,OOO, something like that. I think the GM stood for "gas model" and SGM was "small gas model" and was lighter than the GM. The 0, 00, and 000 were much lighter grades similar to tissue? Feel free to jump in and correct me!
Offline jim welch
Re: K & S Silkspan
« Reply #8 on: May 07, 2016, 01:27:15 PM »
Mike I still have 38 sheets even after selling that...its sgm and oo mixed I cant tell the difference iv'e been putting it on combat planes with dope and auto clear....seems pretty tough when finished...some for you if you need it....Jim :D
AMA 89335
Re: K & S Silkspan
« Reply #9 on: May 07, 2016, 03:01:46 PM »
I don't get why people are still using this stuff with all the modern coverings we have today. Is it just habit?
Re: K & S Silkspan
« Reply #10 on: May 07, 2016, 06:13:35 PM »
There is little else I know of to use to get a very light,  hand rubbed dope finish on,  especially on an open-bay structure.  Silk can be used but requires a lot more dope.   Most anything can be used if finish quality is not a great issue.
Offline mike londke
Re: K & S Silkspan
« Reply #11 on: May 07, 2016, 06:13:46 PM »
Why do people use period correct engines on Vintage Combat planes? Because they want them to be built like they were when they were young. Plastic covering on something designed in the silk and dope days just seems wrong to me.
Offline jim welch
Re: K & S Silkspan
« Reply #12 on: May 07, 2016, 08:31:49 PM »
Mike check your PM's   jim ;D
AMA 89335
Re: K & S Silkspan
« Reply #13 on: May 08, 2016, 05:45:55 AM »
I recently tried some SIG ply-span as a substitute.  Ugh!  Won't make that mistake again.
Re: K & S Silkspan
« Reply #14 on: May 08, 2016, 06:56:28 AM »
I've used the regular ply span ( not lite flight) with some success but it requires more dope so gets heavy pretty quickly .  It is stronger than silk span though.  Great for stunt trainers.
Offline mike londke
Re: K & S Silkspan
« Reply #15 on: May 08, 2016, 07:27:10 AM »
  PM sent.
Offline Jim Svitko
Re: K & S Silkspan
« Reply #16 on: May 08, 2016, 08:54:17 AM »
Google a place called Easy Built Models.  They have mid weight silkspan on a roll, 10 feet long and about 18 inches wide.  As near as I can tell it is identical to the old stuff (Sig, etc.) we used before.  Cost is about $9 a roll.
Offline dennis lipsett
Re: K & S Silkspan
« Reply #17 on: May 10, 2016, 12:23:38 PM »
I haven't used dope or silkspan in about 18 years or so. But, I got curious and went down to the shop looked around and found about 50 sheets of the stuff in various weights.
I've just never been that anal about an extra ounce of weight and have more than often been glad to have it in our windy climate.
Dennis
Offline Dave Harmon
Re: K & S Silkspan
« Reply #18 on: May 13, 2016, 11:29:13 PM »
I got a roll of that....it is just a bit heavier than Jap tissue.
Great for 1/2A or small peanut planes like Easy Built specializes in.
I got some of their house Jap tissue and it worked pretty well. Looks good with about 6 coats of sprayed clear nitrate and 3 sprayed non-shrinking butyrate.
Re: K & S Silkspan
« Reply #19 on: May 16, 2016, 03:18:10 PM »
I also bought silkspan from Easy Built Models and the 10 ft rolls are like the old medium silkspan. Easy to work with.
