  • June 24, 2025, 12:00:11 AM
Author Topic: Can someone splane some about F2D F?D FD??  (Read 2122 times)
« on: January 15, 2007, 12:09:58 PM »
I read about F2D and some other type of F?D and some I don't remember.
Can someone list out all the different types of "D" flying??
Offline RC Storick
Re: Can someone splane some about F2D F?D FD??
« Reply #1 on: January 15, 2007, 12:14:18 PM »
Well there is always the destunt and deracing of coarse here in Missouri were are deicing! I have no clue. Just messing around! LL~
Offline Annette Elmore
    • Lots of UK-related stunt stuff
« Reply #2 on: January 15, 2007, 12:18:46 PM »
It's all to do with the FAI the bunch who control world aeromodelling competitions.
F1 is free flight, F2 is control line, F3 is radio control and F4 is scale.
F2A is speed (max engine size .15 cu in = 2.5cc), F2B is aerobatics, F2C is team racing (.15 ci), F2D is combat (.15ci), F2E is diesel combat (.15ci).
F4B is c/l scale.
Tony
Offline Scott Jenkins
« Reply #3 on: January 15, 2007, 02:37:45 PM »
Rootbeard,
Be advised F2C and F2D are not for the faint of heart these are full blown in your face racing and combat events and thats not to say F2A is for sissys.
Scott F2C, almost a decent pit man.
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
« Reply #4 on: January 15, 2007, 05:57:18 PM »
K this clears some of it up.
I hope to try my hand at slow combat.
« Reply #5 on: January 15, 2007, 07:28:14 PM »
Well, Paul, you don't want F2D, then!  It ain't slow........
The FAI doesn't have slow, that's pretty much a USA event I guess....
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #6 on: January 15, 2007, 07:42:44 PM »
Look here
http://www.modelaircraft.org/insider/06_11/combat.htm
I am a little biased, a real good friend wrote it.... ;)  He has had a lot of fun with F2d and travel.
http://www.go-cl.se/aleksin05.html
F2d is the full blown international combat class.  They use .15 engines that really scream.  They are special motors that turn tiny props 25k+.  They hurt your ears to run.  They are amazing engines.  the airplanes do about 90+.
The cool thing about F2d is that lead to some real innovative airplanes.  The Russian style airplanes are light very strong and turn plenty tight.  I have crashed straight in them without damage.  You can get them ready to fly for not a lot of money.  They work very well with a hot .15 or a normal .25 motor also.
Slow combat is dead in the US, Speed limit is flown more often.  Speed limit has very few restrictions on engines or airplanes, only a top speed of 75 or 80mph.  A 8x4 prop on an LA 25 is about right.
Let do this this summer....
Dave Siegler
NE9N extra class
AMA 720731
« Reply #8 on: January 16, 2007, 05:11:35 AM »
F refers to Section F of the Federation Aeronautic Internationale' Sporting Code.
Sections A, B, C, D, and E cover man-carrying airplanes, balloons, parachuting, spacecraft, etc.
Paragraph 1 covers vol libre,
Paragraph 2, vol circular,
Paragraph 3, telecommade,
Paragraph 4, scale,
Paragraph 5, radio shack.
The lower case letters a, b, c, & d designate individual event; speed, stunt, racing, and combat.
« Reply #9 on: January 16, 2007, 08:34:19 PM »
Here's some combat video from the 2004 World Champs
Elwyn,  good videos.  Brings back memories of the Worlds in Muncie.  Even tho I was confined to F2C during the competition rounds,  still got to see some good matches from even that far away.  The fly aways were spectacular as they arked over into the corn fields.  Thanks,  DOC Holliday
