  • June 19, 2025, 02:31:09 AM
Author Topic: Blank  (Read 5860 times)
Online Rusty
Blank
« on: March 30, 2015, 05:11:38 PM »
Blank
« Last Edit: March 12, 2022, 03:46:43 PM by Air Master »
Offline jim gilmore
Re: I want make .049 handles. Any templates or pictures of good ones?
« Reply #1 on: March 30, 2015, 05:20:38 PM »
Larry  Renger I think designed and somebody sell it. it comes as a kit.
Do a search for him here....
Offline Phil Krankowski
« Reply #2 on: March 30, 2015, 05:36:01 PM »
http://www.exmodelengines.com/product.php?productid=18105&page=1
http://coxengines.ca/1-2a-control-line-handle-for-cox-engine.html
If it sizes down enough you can use quite a few other handles.  Since you are saying you want to make your own duplicate a handle you like in 1/8 inch plywood and aluminum sheet.
Phil
Offline dennis lipsett
« Reply #3 on: March 30, 2015, 07:37:47 PM »
Rusty I'd also recommend the handle by Larry Renger. It's made by Eric Rule at RSM and is light years ahead of the old handles of yesteryear.
dennis
« Last Edit: March 31, 2015, 12:57:26 PM by dennis lipsett »
Offline Roger Vizioli
  • CLiner
« Reply #4 on: March 30, 2015, 10:41:47 PM »
Rusty I'd also recommend the handle by Larry Renger. It's mad bay Eric Rule at RSM and is light years ahead of the old handles of yesteryear.
dennis
I agree w/ Dennis. Larry's handle is the only one I use for 1/2A's. See Vendors corner.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Jim Roselle
« Reply #5 on: March 30, 2015, 11:29:04 PM »
Roger
I third that, it's an outstanding handle.
Offline Larry Renger
« Reply #6 on: March 31, 2015, 08:22:41 AM »
Thanks, guys!  ;D
Offline riley wooten
« Reply #7 on: March 31, 2015, 10:39:01 AM »
Whatever you do keep the handle as light as possible (especially 1/2 A) so you feel the plane, not the handle............
rw
« Reply #8 on: March 31, 2015, 10:59:38 AM »
rw
I was amazed at how much difference it made going from a 100g handle to a 16g handle with a plane that weighs 54 ounces dry.  On a 1/2-A you probably can't make the handle light enough.
« Reply #9 on: March 31, 2015, 11:33:45 AM »
Tim
In the olden days of Dacron lines and low 1/2 A power I put a black mark on the lines at proper place.  That mark went on my point finger, held in place by my thumb.. On those small, ultra light planes my hand was my handle.....
rw
« Reply #10 on: March 31, 2015, 11:35:43 AM »
Tim
rw
Did the line go over more than one finger?  How many (fingers)?
Offline Gerald Arana
« Reply #11 on: March 31, 2015, 11:41:54 AM »
I have had it with the Goldberg red plastic ones I have.  They are old and the plastic isn't holding up good. (having to use plastic glue on them)
Does anyone have a template or instructions / pictures of a good I can make?
I have researched this for days and looked at all I could find, but only one seems plausible for .049.  It had the string clamped between wood in the front.  I think I could make that, but probably there is a better one.
Why don't you just use the one you are gluing back together as a pattern and make your own? ;D
Jerry
« Reply #12 on: March 31, 2015, 12:12:05 PM »
[/quote
Went over all 4 which on my hand was appx. 3-1/2"  Could go down to 3 fingers for closer spacing but I think that is about it. And if you change, remember that changes neutral.
rw
« Reply #13 on: March 31, 2015, 12:40:35 PM »
rw
Thanks.  That makes perfect sense.
Offline GGeezer
    • Gizmogeezer Products
« Reply #14 on: March 31, 2015, 01:37:41 PM »
Rusty,
When I finally converted to a hard point handle for my larger planes, I was so impressed with the handling that I decided to use the same system for my 1/2A models.
I converted a still available Sig 1/2A handle into a Hard-point by simply drilling a series of holes on the front bar of the handle as shown in the photo. I bend the clips in various lengths out of .025 music wire.
This set-up works and feels real good. The handle is very light (16 grams, .6 oz. with clips).
Orv.
Offline GGeezer
« Reply #15 on: March 31, 2015, 03:19:17 PM »
Rusty,
I'll scan and email it to you.
Orv.
« Reply #16 on: March 31, 2015, 03:41:29 PM »
Rusty, if you're at all willing to listen to the "light is good" crowd, I strongly suggest that you use something other than 1/4" ply for this.  1/8" lite ply or 1/16" aircraft plywood should be more than sufficient for this.  1/4" ply will weigh a ton.
Offline GGeezer
« Reply #17 on: March 31, 2015, 06:08:53 PM »
Or heavy cardboard like the handles Jim Walker included with his original Firebabys.
Orv.
« Reply #18 on: March 31, 2015, 08:38:52 PM »
I set up for near equal spacing as the bellcrank.  This spacing is much more narrow than you have.
It looks pretty good.
Phil
Offline GGeezer
« Reply #19 on: March 31, 2015, 11:26:37 PM »
Rusty,
It's fun coming up with a better mouse trap. I too thought that I could build the ideal 1/2A handle and after two disappointing tries decided that there must be an easier and better way, hence the hard-point modified Sig. The thing I like about the hard-point is that I can easily adjust the spacing of the lines. I also make up about a half dozen clips of slightly varying lengths so I can actually set this handle up very quickly to suit the model in question.
I also like how light and touch sensitive it is. The overhang is about as small as you can make for a hard-point so it has good dynamics.
Your handle looks very well crafted but like the folks said, the spacing is probably too wide for those small 1/2A bell-cranks making for a high control rate which degrades flight smoothness and precision.
By all means give 'er a go and see how you like it.
Orv.
« Reply #20 on: April 01, 2015, 06:28:59 AM »
Here's an idea:
whack off the part in front of the knuckles.
reinstall the inserts at the new location, in the now free ends at the cut.
use clevises and a piece of 1/16x1/2 bar aluminum supported by the clevises.  This bar probably can be smaller even.
drill as many holes as desired in the aluminum allowing adjustable spacing and maintaining some trim adjustment.  You will want to use different size clips to do the bulk of the adjustment, with the adjustments for the fine adjustment.
Phil
Offline George
  • Love people, Use things.
Re: I want make .049 handles. I MADE ONE!
« Reply #21 on: April 01, 2015, 07:52:21 AM »
What I did after Orv sent me a template of the Sig handle, I cut the handle out.  I then drill the holes for a 4-40 threaded rod to go in the handle as seen in the picture.  I then drilled the outer part with a 11/32 drill for Dubro 4-40 threaded inserts.  I then put thick CA on the inserts and screwed them into the handle.  After than I put some 4-40 ball link ends on 2" 4-40 threaded rods.   The rods will go out as much as they will go in, giving a good amount of adjustment.   It weighs .7 oz.
I am going to fine sand it and seal it before use, but this is it.   What do you think?
I believe you are intending to make one for each plane. For the next ones:
Measure the hole to hole separation on the bellcrank on the plane that handle is for. Mark the center line on the handle and mark the bellcrank hole spacing centered on that line. Drill for your 4-40 threaded rods so that the lines are spaced the same distance as on the bellcrank.
Making the bellcrank and handle spacing the same will give you a 1:1 movement. That is, if you move the handle 20 degrees, the bellcrank will move 20 degrees. With your handle the way it is, if you have a 1.5" bellcrank and a 3" spacing on the handle if you move the handle 20 degrees, you pivot the bellcrank 40 degrees. That is why many of us who started out with 1/2A planes found them hard to control. Of course the same applies to larger planes.
With the handle you have, you might want to make a larger plywood bellcrank to match the spacing.
In any case, good luck with your handles.
George
George Bain
AMA 23454
Offline Phil Spillman
« Reply #22 on: April 01, 2015, 08:34:45 PM »
Hi Rusty, The Sullivan Co. once made a two holed, for fingers, handle which was just great for small 1/2 A planes. I had one but since our move haven't seen it in 6 years! The lead outs were fixed by a set screw which had a flange to clamp down on the cables and it had a spacing adjustment consisting of a series of larger holes in front of the cables through which the cables were passed to allow for spacing adjustment. The finger holes were large enough to allow for even large fingers to fit through comfortably!
Tally Ho!
Phil Spillman
Phil Spillman
Offline Larry Wong
« Reply #23 on: April 02, 2015, 02:04:34 PM »
This is what I used for years.   y1
Larry
Offline Bob Matiska
« Reply #24 on: April 02, 2015, 03:19:46 PM »
I have one of the handles on the left as well as a whole bunch of the Cox handles. I used it when a buddy and I flew Mouse racers about 40 years ago. There are no markings of any kind on mine, so I had no idea of who made it. Sullivan? That's OK with me. It worked well.
Bob in NEPA
AMA 56267
Offline Keith Renecle
« Reply #25 on: April 02, 2015, 11:17:44 PM »
Hi Guys,
I had to make a quick 1/2A handle from my friend Theo Kleynhans a while ago and I made one using my WHIGLA system. I used a piece of thin hard pressed wood called Supawood out here and then added some balsa for a thicker grip. I just drilled a bunch of holes as you can see in the pics, and then added some ordinary thin string to go in and out of the holes. To adjust you simply loosen the loops and pull them tight again when you are done. As you can see I did not bother to mark the holes properly, hence the skew holes! You could use thin plywood instead of the hardboard.
Oh......what is my WHIGLA system?? What Have I Got Lying Around! #^
Keith R
« Reply #26 on: April 02, 2015, 11:19:43 PM »
O.K. ........here are the pics!
Keith R
Keith R
Offline Bob Hudak
« Reply #27 on: April 03, 2015, 03:21:29 PM »
This one came from an old M.A.N. magazine(not sure which one). the handle is 1/4" balsa laminated with 1/16" ply the grip is 1/4" balso shaped to a comfortable hand grip. the cable is .015 stranded wire. I used a bolt drilled for the cable and a washer and thumbscrew to trap the cable. the hole spacing is 2.25" and 3" on center( I use the 2.25"). Line the holes with plastic tubing(golden rod or similar). A crimp sleeve is all I use to make the eyelets.
Bob
350838
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« Reply #28 on: April 04, 2015, 06:58:29 AM »
People have used the "D" handle from 5 gallon plastic containers. My job happened to get stuff in those buckets. Used 1/16" welding rod to make the hooks.
AMA 77370
Offline jim gilmore
« Reply #29 on: April 04, 2015, 08:09:31 AM »
The screw from a set of bicycle brakes with the hole already in it is the right tool for the job since its used to catch the brake cable.
« Reply #30 on: April 04, 2015, 08:59:14 AM »
I really like that setup on the right.
Phil
Offline John Fitzgerald
  • No longer an AMA Member
« Reply #31 on: April 05, 2015, 09:47:53 AM »
I have a bunch of the Perfect handles and dacron lines, NIB.
