  • July 14, 2025, 05:00:03 AM
Author Topic: Venturi size for an ST .45 R/C  (Read 851 times)
« on: June 28, 2010, 02:36:13 PM »
        I have a friend coming back to Control line after many years and he needs a venturi for his ST .45.I don`t know if the engine timing might be suitable for stunt but I can make one but need to know what would be the desirable ID size for the venturi. All help Appreciated.
Offline TDM
Re: Venturi size for an ST .45 R/C
« Reply #1 on: June 28, 2010, 03:04:33 PM »
Try to post this thread in the Engine set up tips forum.
Second be more specific witch ST .45 motor do you have.
Offline NED-088
    • Heartstrings
« Reply #2 on: June 29, 2010, 03:05:44 AM »
To my knowledge, none of the .45 s were anywhere near a useful stunt timing.
So be prepared to do a lot of work first and being disapointed in the end.... :(
Offline Tim Stagg
« Reply #3 on: June 29, 2010, 07:35:30 AM »
Juan,
I had Byron Barker rework an RC ST 45 which is one of the new Chinese made engines. He hemied the head, did a little minor re-timing work and made the venturi with a sprinkler ST needle valve.
Engine runs a very consistent 2-4 break. he has reworked several of my engines and this one is by far the best. Look in the magazines for CF Slaterly Company, he does a great job and is a heck of a nice guy.
Tim
Tim Stagg
« Reply #4 on: June 30, 2010, 06:51:10 AM »
    Thanks for the advise I`m cleaning the engine and will post a pic as soon as I have it assembled.
