  • July 18, 2025, 02:57:38 AM
Author Topic: I know a guy....  (Read 1936 times)
I know a guy....
« on: April 27, 2010, 09:00:50 PM »
that has a lath. I want to try and make some venturi's. Anyone know what that white plastic looking stuff is called that people make venturi's out of?
And can I get it at Home depot or Lowes?
Thanks!
Re: I know a guy....
« Reply #1 on: April 27, 2010, 09:08:57 PM »
Normally,
its Delrin, not sure about home depot,, I know that Mcmaster Carr used to have it,, mail order
« Reply #2 on: April 27, 2010, 09:10:22 PM »
   Delrin (brand name), Acetal (generic name).
Offline Larry Renger
« Reply #3 on: April 27, 2010, 10:43:38 PM »
For some reason, known in the orient as POM, probably related to the formula?  Nylon would work OK, but is a pain to machine as it is so soft.  Good old Aluminum is easy to machine and readily available.  Also, that should be a "lathe"; a "lath" is a strip of wood, which really is awful to use for machineing anything.  ;)
Offline frank williams
Offline George
  • Love people, Use things.
« Reply #5 on: April 28, 2010, 09:43:14 AM »
...a "lath" is a strip of wood, which really is awful to use for machineing anything.  ;)
It sure holds plaster on the walls, though.  8)
I have used nylon electrical spacers to make venturis a couple of times, but I was not using a lathe. I used a drill press, and an X-Acto. I don't recommend it...go with Delrin or aluminum.
George
George Bain
AMA 23454
Offline Dick Pacini
« Reply #6 on: April 28, 2010, 11:33:56 AM »
UHMW (ultra high molecular weight polyethylene) is an excellent material for that application.  I have machined it many times with great success.
http://www.olsonmfg.com/Material_Distribution/Material_List/UHMW.html
AMA 62221
ChrisSarnowski
« Reply #7 on: April 28, 2010, 03:59:19 PM »
You can make the nylon spacers work but it is miserable to machine. The Acetal / Delrin is much better.
I did the drill press / knife scheme on a few nylon spacers.
You can also get the Acetal rod off the 'bay.
-Chris
  • Gravitywell
« Reply #8 on: April 28, 2010, 07:30:54 PM »
Its also readily available on ebay.
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline don Burke
« Reply #9 on: April 29, 2010, 01:53:57 AM »
Take your pick, 5/8" or 3/4" dia is usually a good start.
http://www.mcmaster.com/#delrin-rod-stock/=6v8s1o
McMaster-Carr usually delivers to me in SoCal in less than two days.
don Burke AMA 843
Menifee, CA
