  • June 17, 2025, 11:45:06 AM
Author Topic: I have litium batteries - now what?  (Read 1782 times)
Offline Terry Caron
« on: February 16, 2016, 01:36:32 PM »
I've recently been bitten by the ignition engine bug and bought Lipos in the interest of weight-saving.
They came with no information whatsoever and I know there are real safety concerns when it comes to charging them.
The ones I bought are 3.7v 1100mah, meant for use in a particular multi-rotor (Syma X5SC X5SW S39D) and have a minimalist, nonadjustable charger with a UBS connector for power but no input/output specs.
On the assumption I shouldn't plug into my computer, what are "Safe Practices" for charging?
Terry
« Last Edit: February 16, 2016, 01:59:10 PM by Terry Caron »
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline mike londke
Re: I have litium batteries - now what?
« Reply #1 on: February 16, 2016, 02:10:46 PM »
Terry I have "smart" LiPo balance charger that you, can use. I bought it when Larry drug me into electric R/C. It's pretty stupid proof. Even I figured out how to use it. Just come get it.  Mike
Offline Terry Caron
« Reply #2 on: February 16, 2016, 03:16:11 PM »
Great and thanks, Mike!
Makes it simple.
Terry
AMA 249824
NRA Life Member
Offline John Rist
« Reply #3 on: February 16, 2016, 06:05:22 PM »
Just remember that LiPo batteries should not be discharged below 80% full charge.   Most speed controllers used in Eflight have a built in cutoff at a safe level.  When used as a battery in a ignition system it will up to you not to over use it.  However I suspect that the current draw in you application will be very low.  Battery run time should be very long.   good luck - it should work well     #^
Offline Terry Caron
« Reply #4 on: February 16, 2016, 06:09:22 PM »
Thanks, John.
I can do manual checks on the voltage with the VOM.
Terry
AMA 249824
NRA Life Member
Online Dennis Toth
« Reply #5 on: February 17, 2016, 06:12:09 PM »
I think John meant that the Lipo should only be discharged 80% leaving 20% still in the battery. The most important piece of equipment for electric power is the charger. You can get almost any brand of Lipo but you need a charger designed for Lipo packs. I like any of the charges from Thunder Power.
Best,     DennisT
Offline Terry Caron
« Reply #6 on: February 17, 2016, 06:17:49 PM »
Correction noted, Dennis, thanks.
I picked up the smart charger from Mike today, so I'm good to go - if I'm smart enough to figure out the operating procedure.  ;D
Terry
AMA 249824
NRA Life Member
Offline John Rist
« Reply #7 on: February 17, 2016, 07:48:01 PM »
Best,     DennisT
Well said!  I was never known for my English skills.   n~   LL~
« Reply #8 on: February 18, 2016, 09:19:23 AM »
Good article in Model Aviation on lipo's.   But, RC column that most don't look at.
