  • July 17, 2025, 08:08:00 PM
Author Topic: Hexavalent Chromium Disposal  (Read 3513 times)
« on: November 09, 2014, 09:03:55 PM »
Was cleaning out the shop and found a gallon of my old chrome plating solution. I've been all over the internet and haven't found how to properly dispose of this stuff. Anyone have a suggestion.
Re: Hexavalent Chromium Disposal
« Reply #1 on: November 09, 2014, 09:05:50 PM »
Weed killer?
Offline RC Storick
« Reply #2 on: November 09, 2014, 09:13:01 PM »
That is some wicked stuff. Call county recycling. Maybe and I do mean maybe they will take it.
http://www.saif.com/_files/SafetyHealthGuides/SS-835.pdf
Offline Dick Pacini
« Reply #3 on: November 10, 2014, 01:10:23 AM »
Call a local plating shop and ask if they will take it, for a fee if necessary.
AMA 62221
ChrisSarnowski
« Reply #4 on: November 10, 2014, 05:10:39 AM »
Couldn't you chrome up some cylinders with it? Just a thought. Maybe the depleted solution still would be too nasty.
« Reply #5 on: November 10, 2014, 07:07:52 AM »
« Reply #6 on: November 10, 2014, 09:39:57 AM »
I'll be right over.
Cool. I've got bit of a stray cat problem, too. This ought to take care of both issues.
« Reply #7 on: November 10, 2014, 10:10:17 AM »
How much trouble that'll get you into varies a lot from state to state, and of course by whether you get caught.  I'm pretty sure it's illegal no matter where you are (and hexavalent chromium is way nasty stuff, so you won't get a pass based on it being not that bad).
In Oregon, at least, the state provides no-questions-asked hazardous waste disposal for homeowners.  As long as it doesn't look like you're running a business involving the chemicals, they want to take it off your hands rather than have you dump it down a drain pipe.
« Reply #8 on: November 10, 2014, 10:57:45 AM »
I even called Caswell plating and they didn't have an answer. They said they use to have a product that would balance the ph and make it safe, wrong. Called a few plating shops and they won't touch it and were very cagey about what they do with theirs. I'm thinking scheduled 40 pipe with two end caps then mail it to Baghdad. I guess I'll just keep it and keep using it then take it to the grave so I can chrome the devils horns.
« Last Edit: November 10, 2014, 11:22:22 AM by Motorman »
Offline Bill Morell
« Reply #9 on: November 10, 2014, 11:24:48 AM »
Use it to plate Bill Little Orwick parts for him.
Bill Morell
Vietnam 72-73
« Reply #10 on: November 10, 2014, 11:29:50 AM »
Hi Bill,
I'll second that, third it, etc..
BIG Bear
RNMM/AMM
Offline Dick Pacini
« Reply #11 on: November 10, 2014, 03:03:55 PM »
I wasn't suggesting anything cagey.  My thoughts were if plating companies still use that product, they may want it.  If they don't use it but have a legitimate disposal service, they may take it for a fee.  I don't see how either scenario would ruffle the state's feathers.
AMA 62221
Offline Mike Keville
« Reply #12 on: November 10, 2014, 04:14:49 PM »
Isn't that the stuff that contaminated the groundwater at Hinkley, CA several years ago, resulting in numerous cancers and other illnesses and ultimately a multi-million $ lawsuit against a major CA corporation?  (Think "Erin Brockovich").
« Last Edit: November 10, 2014, 04:55:26 PM by Mike Keville »
« Reply #13 on: November 10, 2014, 04:51:27 PM »
In Oregon at one time (and possibly still -- thankfully I haven't had to worry about that since my early 20's) that would have been unlicensed disposal of hazardous waste -- you had to have a license to accept any hazardous waste for disposal, which came with all sorts of hoops you had to jump through, and it all went well beyond what you needed to do to legally use hazardous material (and, hence, generate hazardous waste).  The intent was to keep unscrupulous people from setting up as hazardous waste disposal companies and just dumping the stuff into a creek somewhere.
Since the people enforcing the rules were all bureaucrats, and environmental do-gooders fresh out of college to boot, that meant that if you did accept hazardous waste you were still treated like you ate little babies for breakfast even if you were scrupulously proper in how you disposed of it.
« Reply #14 on: November 10, 2014, 04:56:56 PM »
See my question in Reply #12 above!
Offline Dick Pacini
« Reply #15 on: November 10, 2014, 05:55:35 PM »
When I read the original post, I didn't get the impression it was waste, but rather an unopened container of the product, which could be used.
I am well aware of the "cradle to grave" process when dealing with industrial products.  I owned a small manufacturing company for 22 years and a large part of our overhead was disposal of regulated waste.  Every six weeks when the Safety-Kleen truck pulled in, you could hear my checkbook scream.
I was very careful what I allowed in the door.  Even household products are treated differently.  Use Simple Green at home and dispose of the dirty solution down the drain.  Use it in a manufacturing environment and it needs to be drummed up for "proper" disposal.  It used to cost $185/drum for our waste which included dirty coolant, tramp oils, absorbent pads and Speedy-Dry.
I am glad to be out of it.
AMA 62221
Offline Douglas Ames
« Reply #16 on: November 10, 2014, 08:31:36 PM »
The current primer in use at the Airline I work for has that in the mix. Toxic sh*t!! Handle it accordingly.
Tulsa, OK has an amnesty day to get rid of such stuff... Might check with your local authorities.
AMA 656546
« Reply #17 on: November 10, 2014, 08:58:01 PM »
Once again:  Google Erin Brockovich.
« Reply #18 on: November 10, 2014, 09:44:29 PM »
Found this blurb while searching.
"For nearly a century, Honeywell and PPG disposed of more than ONE MILLION TONS of hexavalent chromium waste at over one hundred sites across Jersey City".
Next time you're worried about your carbon foot print think about that and you might not feel so bad.
Offline Arlan McKee
« Reply #19 on: November 11, 2014, 07:13:54 AM »
If you can't find someone to take it for disposal I can tell you how to convert it from hexavalent to trivalent chromium and finally to chromium hydroxide, neither of which are carcinogenic.
« Reply #20 on: November 11, 2014, 08:43:05 AM »
I think I'm there so, go ahead and tell me.
Offline Arlan McKee
« Reply #21 on: November 11, 2014, 09:22:13 AM »
I sent you an email.
