  • June 26, 2025, 05:03:36 PM
Author Topic: Decals  (Read 796 times)
Offline peabody
Decals
« on: February 17, 2019, 05:16:00 AM »
Has anyone succeeded in creating waterslide decals made with Ink Jet printers of late?
I tried years ago and it was a disaster.
I bought a couple from Tom Morris around that time and screwed them up too.
Offline John Paris
Re: Decals
« Reply #1 on: February 17, 2019, 06:37:23 AM »
Rich,
I did a set of Chipmunk decals that turned out okay.  Need to be sure to spray some Krylon clear before exposure to water.
John Paris
269
Offline Chris Fretz
Re: Decals
« Reply #2 on: February 17, 2019, 09:43:13 AM »
I have had good luck with Testors White Decal water slide paper. The hardest part is getting the print area set up.  After printing it I spray light coats of clear dope on it.  Then apply it to the model. Clear dope the whole airplane. People say the colors fade pretty bad in the sun light. I spray Max 2K clear on the decals and none of mine have faded at all.
Chris
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F112660137529
https://www.amazon.com/dp/B0043B7UQY/ref=cm_sw_r_sms_awdb_t1_M6yACb9EFZN7G
Formerly known as #Liner
AMA 1104207
Advanced
Re: Decals
« Reply #3 on: February 17, 2019, 02:30:04 PM »
I've had good success.  If you bought finished decals from Tom Morris and had problems, then perhaps it was your handling?  Or did you buy decal paper?
At any rate -- I used decal paper from some coffee cup company.  I just followed the directions and had success.  My only mistake was buying matt-finish lacquer; the matt-finish was accomplished in a way that printed through the dope I painted over the decal, and required some careful sanding to smooth things out.
Mark_Gerber
Re: Decals
« Reply #4 on: February 17, 2019, 04:09:56 PM »
Rich,
I've had good luck with Papilio products and inkjet printing.  I think I first heard about these from Windy.
https://www.papilio.com/
Mark Gerber
Offline peabody
Re: Decals
« Reply #5 on: February 17, 2019, 06:12:18 PM »
I'll try again...
It seems to me I was using a manufacturer provided setting agent...I'm going to run a bunch of 1/16" FAA numbers.
Re: Decals
« Reply #6 on: February 17, 2019, 06:31:27 PM »
Get some panes of glass or smooth coffee cups and try it out there, first!
