  • June 16, 2025, 11:52:13 PM
Author Topic: help on tony kitty  (Read 1037 times)
Offline Brent Rogillio
help on tony kitty
« on: May 24, 2022, 02:25:56 PM »
On a tony kit from Rsm does the fuse sides curve and glue on the formers on the bottom. This is pretty good bend.
Offline Dallas Hanna
Re: help on tony kitty
« Reply #1 on: May 24, 2022, 09:17:35 PM »
Google "Warburton Tony" and you will find the plan of original plus the mag docs for reference on Outerzone.
.  Not sure how true to plan/kit from RSM is to Warburton's
« Reply #2 on: May 24, 2022, 11:08:30 PM »
Knowing the poms , that era , they probably PLANKED IT . 1/4 x 1/8 strips . Balsa cement . PVA and youll ad 5 Ton. .
These Warburtons were at the top of the heap in the U K as radical disadent designers !  https://outerzone.co.uk/search/results.asp?keyword=Frank%20Warburton&Xresultsview=Extended
Dunno if thisisa relitive .
« Last Edit: May 24, 2022, 11:25:48 PM by Air Ministry . »
« Reply #3 on: May 24, 2022, 11:14:09 PM »
Hipocket or outerzone ? lists AEROMODELLOR magazine scans . So it could be there , wherever it is .  S?P
« Reply #5 on: May 25, 2022, 09:18:26 AM »
While the original may have used strips/planking method, most builders these days would mold top and bottom shells from 2 or 3 layers of 1/32 sheet...pretty tough with the laminating glue. Making the pattern to mold the balsa is a new skill that isn't that difficult and I'm sure that has been pretty well covered in the Building Forum. Selecting the right piece of balsa, add HOT water (some add ammonia), Ace elastic bandages, patiently waiting for it to dry, etc. Some like Titebond, while others use epoxy. Some folks add a layer of carbon vail between the laminations. Add some 1/16" bulkheads every 5"-6" and you got it.  H^^ Steve
« Reply #6 on: May 25, 2022, 11:53:53 AM »
I was able to wet it and make the bend. Thanks for the response
