  • June 30, 2025, 08:57:27 AM
Author Topic: What do you use?  (Read 1005 times)
Offline steve pagano
What do you use?
« on: October 13, 2007, 09:51:56 PM »
     I am currently in the process of buffing my plane. I have never done this before so i could use some suggestions. After letting my clear coats dry i wet sanded with 600 just enough to dull the clear the rubbed it out with "No7" polishing compound. It did give me a some what of a shine but should i use something else? I was thinking of 3M's ''FinalShine" What do you think?
                                      T.I.A
                                         -Steve
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline Keith Spriggs
    • khspriggs
Re: What do you use?
« Reply #1 on: October 13, 2007, 10:32:52 PM »
I hate to break the news to you, but 600 is too coarse for the clear coat. I painted my cars with single stage which is the same as clear except it has a pigment in it. The coarsest paper I ever used was 1000 and only that coarse if there was some major flaw to remove. Most of the time I used 1500 followed by 2000. If you go over it with 2500 hardly any buffing is required. Be sure and put a few drops of detergent in the water for wet sanding. Change water often. Use a soft sponge and clear water to remove the residue as you sand.
There are some expert finishers on this forum that know far more than I do in regard to finishing model planes as most of my experience has been with cars. Hopefully some of them will jump in here.
Don't make me name names Robert LOL
« Reply #2 on: October 13, 2007, 10:36:41 PM »
Keith,
     Do i need to follow 1500 grit with 2000 or can i just hit it with 2000?
A.M.A. 820-823
« Reply #3 on: October 13, 2007, 11:31:44 PM »
Steve, I think you will need the 1500 to take out the scratches the 600 has made, then the 2000.
Offline Ron King
« Reply #4 on: October 15, 2007, 04:31:32 AM »
Keith is right. I used to think 600 was "very fine". Now I think 1200 is "coarse".  :## :##
!500 is a good "medium" grit to start off with. Live and learn.
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
