General control line discussion => Open Forum => Topic started by: steve pagano on October 13, 2007, 09:51:56 PM
I am currently in the process of buffing my plane. I have never done this before so i could use some suggestions. After letting my clear coats dry i wet sanded with 600 just enough to dull the clear the rubbed it out with "No7" polishing compound. It did give me a some what of a shine but should i use something else? I was thinking of 3M's ''FinalShine" What do you think?
T.I.A
-Steve
I hate to break the news to you, but 600 is too coarse for the clear coat. I painted my cars with single stage which is the same as clear except it has a pigment in it. The coarsest paper I ever used was 1000 and only that coarse if there was some major flaw to remove. Most of the time I used 1500 followed by 2000. If you go over it with 2500 hardly any buffing is required. Be sure and put a few drops of detergent in the water for wet sanding. Change water often. Use a soft sponge and clear water to remove the residue as you sand.
There are some expert finishers on this forum that know far more than I do in regard to finishing model planes as most of my experience has been with cars. Hopefully some of them will jump in here.
Don't make me name names Robert LOL
Keith,
Do i need to follow 1500 grit with 2000 or can i just hit it with 2000?
Steve, I think you will need the 1500 to take out the scratches the 600 has made, then the 2000.
Keith is right. I used to think 600 was "very fine". Now I think 1200 is "coarse". :## :##
!500 is a good "medium" grit to start off with. Live and learn.
Ron
