Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 22, 2025, 10:12:02 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Hellcat #152 with Polyhedral
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Hellcat #152 with Polyhedral (Read 935 times)
Pat Johnston
Trade Count:
0
Commander
on:
August 31, 2011, 07:11:13 AM »
Hellcat design #151 was set up with a small amount of dihedral. Ol' WW thought it would be better looking if the dihedral breaks which happen on the scale model would be used. These are about a bay outside of the landing gear. This evolved into design #152 which has a flat center section and polyhedral breaks at rib #5. The wing sheet (#2) shows a frontal view so the spars can be set up before framing the wing. The wing is build in halves and the ribs have the jig holes set so the wing will have the appropriate polyhedral break at rib #5 location. The fuselage sheet (#1) did not need to change in any way. Both halves of the wing are attached together so the bottom of the center section is flat. This accentuates the polyhedral breaks a little bit. Give it a gander. PDF files attached.
Pat Johnston
Advanced Stunt Design
Skunk Works
Logged
Rick Henry
AMA Member
Trade Count:
0
Lieutenant
Re: Hellcat #152 with Polyhedral
Reply #1 on:
August 31, 2011, 07:22:12 AM »
That really looks cool Pat. I will say it again. I love your designs.
Rick Henry
Logged
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #2 on:
August 31, 2011, 11:44:49 AM »
This stunter, sort of a 1930's British lightplane, has the dihedral break at the landing gear location. The center section is flat.
Logged
AMA #796 SAM #188 LSF #020
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Reply #3 on:
August 31, 2011, 01:51:21 PM »
Another design with scale dihedral break - Don Hutch's "Dauntless". Not so hard to do.
Logged
Pete Cunha
Sacramento CA.
AMA 57499
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
