  • July 17, 2025, 01:37:49 AM
Author Topic: Sanding primer  (Read 1081 times)
Offline stephen hollier
Sanding primer
« on: May 28, 2012, 09:16:24 PM »
I use automotive primer what grit sand paper do you use? i have been using 400 grit and wet sand.
Thanks for the help
Re: Sanding primer
« Reply #1 on: May 28, 2012, 09:49:55 PM »
lacquer or catalyzed,,
regarless, you could start with 240, go to 320 then finish with 400,, the courser paper you start with, the straighter the resultant surface will be
Re: Sanding primer
« Reply #2 on: May 28, 2012, 10:18:51 PM »
Mark, I was going to say that myself, but it's been so long I couldn't remember if it applied over open bays.
Do you really start with 240 over open bays, or do you start finer?
Re: Sanding primer
« Reply #3 on: May 28, 2012, 10:28:21 PM »
depends, I start with what I need to use to get rid of the testure I am getting rid of,, it takes what it takes,, if your primer is nice and smooth with no orange peal, then 320 would be fine, if you have orange peal, ( or grapefruit skin)  ;D sometimes its better to hit it a good one shot with 240 to cut the tops off,, My avenger was finish sanded with 320,, no lie,, that was my final sanding on the surfacer,, because I knew I was spraying a sealer coat over it and that would hide the 320 scratches,,
OBTW, next column,, sandpaper
Offline Allan Perret
  • Proverbs
Re: Sanding primer
« Reply #4 on: May 29, 2012, 06:07:43 AM »
What Mark said sounds real close to what I do.
I do it dry, wet sanding at the primer stage is too messy.  Much easier to blow or wipe off the sanding dust.
I sand the primer/surfacer to 320, then shoot a clear coat and sand that to 400~600 before going to color coat.
I never do any wet sanding till I get to color, trim, and clear coats.
Steve, you going to Dallas contest ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Sanding primer
« Reply #5 on: May 29, 2012, 06:37:16 AM »
Thanks guys it's been awhile since I finished a model.
Allan- My current plans are to attend Dallas. I will keep you informed if things change. How about you?
  • Proverbs
Re: Sanding primer
« Reply #6 on: May 29, 2012, 08:24:42 PM »
I'm a strong maybe right now.  Depends if I get someone else to come along.  Also plan to watch wind & weather forecast and cancel at last minute if I dont like what I see.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Sanding primer
« Reply #7 on: May 30, 2012, 09:42:11 AM »
Last Sunday must have been windy nation wide.   I want to thank those that stayed home because of the wind.  I would not have gotten first if a few would have showed up.   Jim Kraft was there, but the doctor has him on limited exercise/activity.   His lovely wife was keeping a good eye on him too.
Now back to the subject I did a wet sanding job on one plane years ago.  Never again.  After blowing dust off plane, I use a slightly damp rag to wipe it down.  220 grit for most of my sanding,  guess that is why it takes so long.   ALso a good sanding block of appropiate size. H^^
