General control line discussion => Open Forum => Topic started by: stephen hollier on May 28, 2012, 09:16:24 PM
I use automotive primer what grit sand paper do you use? i have been using 400 grit and wet sand.
Thanks for the help
lacquer or catalyzed,,
regarless, you could start with 240, go to 320 then finish with 400,, the courser paper you start with, the straighter the resultant surface will be
Mark, I was going to say that myself, but it's been so long I couldn't remember if it applied over open bays.
Do you really start with 240 over open bays, or do you start finer?
depends, I start with what I need to use to get rid of the testure I am getting rid of,, it takes what it takes,, if your primer is nice and smooth with no orange peal, then 320 would be fine, if you have orange peal, ( or grapefruit skin) ;D sometimes its better to hit it a good one shot with 240 to cut the tops off,, My avenger was finish sanded with 320,, no lie,, that was my final sanding on the surfacer,, because I knew I was spraying a sealer coat over it and that would hide the 320 scratches,,
OBTW, next column,, sandpaper
What Mark said sounds real close to what I do.
I do it dry, wet sanding at the primer stage is too messy. Much easier to blow or wipe off the sanding dust.
I sand the primer/surfacer to 320, then shoot a clear coat and sand that to 400~600 before going to color coat.
I never do any wet sanding till I get to color, trim, and clear coats.
Steve, you going to Dallas contest ?
Thanks guys it's been awhile since I finished a model.
Allan- My current plans are to attend Dallas. I will keep you informed if things change. How about you?
I'm a strong maybe right now. Depends if I get someone else to come along. Also plan to watch wind & weather forecast and cancel at last minute if I dont like what I see.
Last Sunday must have been windy nation wide. I want to thank those that stayed home because of the wind. I would not have gotten first if a few would have showed up. Jim Kraft was there, but the doctor has him on limited exercise/activity. His lovely wife was keeping a good eye on him too.
Now back to the subject I did a wet sanding job on one plane years ago. Never again. After blowing dust off plane, I use a slightly damp rag to wipe it down. 220 grit for most of my sanding, guess that is why it takes so long. ALso a good sanding block of appropiate size. H^^
