  • June 19, 2025, 01:33:26 PM
Author Topic: Half-A plastic parts  (Read 7131 times)
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
« on: April 21, 2024, 12:27:48 PM »
Hi. I'm teaching a group of kids to build C/L planes. A few years ago, I bought 100 of each of the plastic motor mount and the bell crank shown in the photo. But I haven't been able to find them sold in bulk again. Does anyone know where to get them?  Also, the rubber fuel bulb shown, is out of stock at Cox International.
Dave Nyce   New Bern, NC
AMA: L356
Offline Steve Berry
Re: Half-A plastic parts
« Reply #1 on: April 21, 2024, 12:41:39 PM »
Brodak has one in stock.
https://brodak.com/fuel/pumps/sullivan-bulb-pump-4oz.html
Sent from my SM-N986U using Tapatalk
Offline Dave Nyce
  • Flying
« Reply #2 on: April 21, 2024, 12:56:12 PM »
Brodak has the larger, red one, in stock, at 4 ounces. I'm looking for the 2 ounce size that is better-suited for the 1/2A engines. (The kids like to copy what I'm using.)
AMA: L356
Online 944_Jim
« Reply #3 on: April 21, 2024, 03:21:41 PM »
Mr. Dave,
I'm cheap...painfully cheap!
Last year's trailer and car license plates gave me enough material to make lots of "Cox engine mounts." Simply cut two rectangular plates (roughly 1"x1-1/4") and fold the short edge up to a right angle about 7/16" from the edge. Drill matching holes between the long sides and your fuselage, then hold an engine in place to mark the engine mounting holes. These aluminum plates are light and will last as long as the plane. I can attach a picture later if you need.
« Reply #4 on: April 21, 2024, 04:43:13 PM »
  I know I have seen those plastic engine mounts somewhere online recently, and I just can't place it. I think those came with the Estes/Sterling 1/2A kits, maybe? I may have seen them in bulk on eBay.
Offline Mike Hazel
« Reply #5 on: April 21, 2024, 05:06:59 PM »
Dave,
I have the bellcranks and elevator horns in bulk.  PM me to discuss.
Offline bill bischoff
« Reply #6 on: April 21, 2024, 09:15:58 PM »
Dave, I salute your noble effort. I will be sending another care package, containing one Sterling 1/2A parts pack with motor mount, bellcrank, and horn, one loose Sterling motor mount, three bellcranks with horns, and I also have 4 of the Dubro #148 1/2A battery clips in package if you want them. Do you need any small line connectors? I probably have at least a dozen cluttering up my line clip box.
The motor mount in your photo looks like the Brodak one, or at least squirted from the same mold. Perhaps they will sell you some loose ones in bulk. Same goes for the bellcranks.
Bill Bischoff
« Reply #7 on: April 21, 2024, 09:46:33 PM »
As an alternative to Sullivan bulbs, you can get 2 oz. polyethylene squeeze bottles on Amazon for well under a dollar each in quantity. I saw 100 pcs for $27.00. Select ones with a top that will work as is, or accept a brass tube spout.
BB
« Reply #8 on: April 21, 2024, 10:23:24 PM »
  I'll be digging through my tank collection looking for a tank for a project. I have a ton of the square small Perfect brand metal tanks. If just for going round and round and pulling positive G for a loop or wing over now and then, they should work. Ping me back if interested.
Offline Dave Nyce
  • Flying
« Reply #9 on: April 22, 2024, 09:02:38 PM »
Looks like Mike can supply a bulk quantity of the bell crank. So, now I am looking for the plastic engine mounts.
AMA: L356
« Reply #10 on: April 22, 2024, 10:16:14 PM »
Just a side note, I've never had a Sullivan bulb that didn't deteriorate inside and leave small flicks of rubber in my tank/filter/nva. I won allot of races because people used those and I didn't. ymmv.
« Reply #11 on: April 23, 2024, 12:22:12 AM »
Brodak has the mounts and bellcranks:
https://brodak.com/1-2-a-motor-mount.html
https://brodak.com/brodak-c-40-1-2a-bellcrank.html
Unfortunately, they're now quite expensive.  If you're making lots of mounts, you can do what I did.  Go to Home Depot or some other home improvement store and buy 1/16" aluminum angle and cut it down to1" pieces, then drill for the engine mounting holes and fuselage mounting holes.
Online Dave Rigotti
« Reply #12 on: April 23, 2024, 05:59:10 AM »
For motor mounts try Vintage Performance Model Airplanes.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Jim Catevenis
« Reply #13 on: April 24, 2024, 04:59:33 AM »
PM sent.
Jim
Online 944_Jim
« Reply #15 on: April 29, 2024, 07:35:51 PM »
That looks home-brew 3d printed. I wonder if the stl file can be found online?
Offline Paul Wescott
« Reply #16 on: May 14, 2024, 05:18:18 PM »
Or how many guys on this forum could create a generic STL file and post it for all to use.  Although I’m leery of 3D printed “structural” items, especially those subject to vibration.  If the kids can build the rest of the plane from wood, how about having them build the same motor mount also from wood?
Offline John Gluth
  • Knight 1992
« Reply #17 on: May 15, 2024, 08:57:31 AM »
Helpful thought Paul.
Motor mount doesn't seem currently available at Vintage Performance Model Airplanes.
As a youngster, friends and I made and used plywood motor mounts likely for a fraction of printed plastic $ cost.
Good answers come only from asking the right questions.
Offline Dave Nyce
  • Flying
« Reply #18 on: May 15, 2024, 09:01:36 AM »
Yes, sometimes we build a plywood firewall, like with the Skyray. But sometimes we like to use the plastic molded version, if available.
AMA: L356
Online Dave Rigotti
« Reply #19 on: May 15, 2024, 10:21:22 AM »
Is or isn't it?
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #20 on: May 15, 2024, 01:16:51 PM »
I like using the plastic Brodak mount for most of my 1/2A builds, as they are mostly profile planes.  It's just quicker and easier to get a properly aligned engine.  Also, when I build the fuselage, I put a couple of hardwood dowels where the two mounting screws go so that the holes don't elongate over time.  I can also use one engine mounted to the Brodak mount and swap it between multiple planes in just a couple of minutes.
« Reply #21 on: May 23, 2024, 12:00:06 PM »
For the motor mount I'd look on Thingyverse for the file.  Our local library has a 3d printer: you email the file to them, they priint it, and a couple days later you go to the local library and pick it up.  Easy!
Online Dave Rigotti
« Reply #22 on: May 23, 2024, 07:25:21 PM »
I wonder how they would feel getting 50+ pcs to print?
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online 944_Jim
« Reply #23 on: May 23, 2024, 08:43:37 PM »
I've been looking for the STL or G-Code (print files). No dice. I think Vintage Performance (Stan F.) created the source files as their name IS on the side. I doubt he would let the files go.
If anyone has those files, then it takes one more piece out of the hands of Brodak, RSM, Cox International, or any of their resellers.
Sheesh...I gotta learn my 3d printer.
« Reply #24 on: May 24, 2024, 06:25:41 AM »
As long as you send them the files one per email, they don't seem to mind.
« Reply #25 on: May 24, 2024, 06:34:38 AM »
That wasn't my intention.  I referred to Thingyverse since it seemed no one had one for sale.
I searched Thingyverse and they didn't either.  So, wrong assumption on my part.
Frankly, I wish these resellers were making money hand over fist since that would be a pretty good indication of the health of the hobby.
Offline Mark wood
« Reply #26 on: May 24, 2024, 08:21:59 AM »
These kind of parts are easy to sketch up in many freely available CAD programs. The trouble with a lot of parts and sending to someplace is the material being used. For a model that will never sit inside a car or covered truck PLA can work. PETG would be better but it is an unknown whether the place you send your part to will have PETG. For a 1/2 A model straight up PETG would be fine. For anything large a glass or carbon blended material is necessary which most printers won't do a good job of printing as they generally require an enclosed environment. I know, someone will pipe in and say I do it the time on my open frame printer. I'm simply telling you about what my testing has shown  and I've done a ton of testing.
Send me a PM Scott
Life is good AMA 1488
Online 944_Jim
« Reply #27 on: May 24, 2024, 06:57:40 PM »
Mr. Scott,
It was only an observation. I'm a pretty heavy diy kind of guy. Unfortunately I have too many irons on the fire right now. Worst part is I have a small CNC 3d cutter and a 3d printer. Both have the same platen as one of the 3018 machines. Shoot, I haven't flown a plane since winter!
Mark,
Do you have a 3d printer? If not, but you have the "engineering side," maybe we could work something out. I don't know how viable such an arrangement may look given my schedule. But if the code were drop-in and print, I'd stamp out a dozen to start Mr. Dave out. It would be the incentive to light up the printer.
Offline Mark wood
« Reply #28 on: May 24, 2024, 08:14:59 PM »
Mark,
I do. And I have the right Knowledge, skills and materials to do this job. I actually intended the PM comment for the OP.
Dave Nyce you could PM
« Reply #29 on: May 25, 2024, 05:32:36 AM »
No problem!  The same here except I haven't had the time to get into 3D printing except the few things I have sent over to the library to print for me: a little sanding block and exhaust pipes for my planes (an easy dress-up for almost any plane.)
« Reply #30 on: May 25, 2024, 05:39:32 AM »
In the past having done similar to what David Nyce is doing, I am sure that he would appreciate any encouragement or support you could provide him.  A lot of people simply don't recognize the vaue of the "building side" of our hobby.  Even some within our hobby!  There is simply no better thing a young man could be involved in than our hobby - particularly the building arts.
Offline Mark wood
« Reply #31 on: May 25, 2024, 05:48:16 AM »
Well, my list of 3d printing application for model airplanes is quite extensive and my experience resulting from failures doing so has taught me a lot about what is necessary for success. That exhaust is a perfect thing.
The 1/2 A parts would be simple enough and made from CF impregnated PET would be durable. For a good cause, I would probably donate my time.
