  • July 06, 2025, 09:35:49 AM
Author Topic: Good OS 25 size plane  (Read 9584 times)
Offline JIM Nordin
« on: May 06, 2015, 07:06:37 PM »
I ordered a OS 25 LA  and was all set to get the Brodak Goldberg Shoestring . Now I'm wondering  what else is out theren there . I been looking at the Fancy pants  The magician the vampire the the 25 size Stuka the Smoothie
 These are all from Brodak
Thanks JIM
Re: Good OS 25 size plane
« Reply #1 on: May 06, 2015, 07:17:03 PM »
Jim,
I would get a second engine and build a twin!!!  ;D
I have a twin in my bucket.  #^
Offline Dennis Moritz
« Reply #2 on: May 06, 2015, 07:54:29 PM »
Many mid size profiles are excellent choices for that engine. Shoestring as good as the rest. Which would include any of the Streaks, other CG Brodak Profiles, Buster, Cosmic Wind. I've seen the Shark 402 win stuff at local contests in Advanced powered by a similar engine. Fancy Pants, Barnstormer, also appropraiate. If you want to build a full fuse plane.
Mike Griffin
« Reply #3 on: May 06, 2015, 08:34:19 PM »
Dennis just gave you some excellent suggestions .  My choice would be a Streak.
« Reply #4 on: May 06, 2015, 09:37:12 PM »
It depends on your skill level.  I had an LA 25 in a Sig Skyray which made a very nice combination.  I've been told by numerous smart people that a plane that would work well with a Fox 35 would work well with an LA 25, but I haven't had the courage to try (other than the Skyray).
Offline Larrys4227
« Reply #5 on: May 06, 2015, 09:37:54 PM »
My one and only OS25-LA has been on a SuperClown its entire life - 8 years .... excellent combination
Offline GonzoBonzo
  • GonzoBonzo
« Reply #6 on: May 07, 2015, 12:43:43 AM »
Hey Jim,
What do you plan to do with it, learn the pattern, or sport fly?
Gonzo
Online kenneth cook
« Reply #7 on: May 07, 2015, 03:27:48 AM »
               I truly enjoy flying my Brodak Magician with the LA .25. Ken
Offline Larry Fernandez
« Reply #8 on: May 07, 2015, 08:23:29 AM »
A Still Stuka or Jetco Dolphin.
Even a light Nobler
-Larry, Buttafucco Stunt Team
« Reply #9 on: May 07, 2015, 09:35:51 AM »
Even a light Nobler
   The Still Stuka would be a good choice, and the Dolphin is a proven winner (with a Veco 19, which is a tad weaker than a 20FP). I was going to build a Stuka but a local flier had one that was so good I couldn't bring myself to build  one and thus suffer by comparison.
« Last Edit: May 07, 2015, 10:46:24 PM by Brett Buck »
Offline Larry Borden
« Reply #10 on: May 07, 2015, 10:01:06 AM »
And the Ringmaster.
Offline JIM Nordin
« Reply #11 on: May 08, 2015, 07:18:39 PM »
Tanks for all the information guy much apprciated  .  I'm a sport flyer formtHe most part I'll,learn the the pattern and  the plane I need  should be capable of doing the pattern  and knock of a lot of rust that I have
JIM
« Reply #12 on: May 08, 2015, 09:18:02 PM »
And the Ringmaster.
  Way too small.
« Reply #13 on: May 09, 2015, 01:46:31 PM »
I have another one just about ready for paint.
You know the last one was scattered all across the pavement at Whittier Narrows. (I hate it when that happens)
The aft section is sticking out of the wall at Warren Walkers "Man Cave". It makes for an interesting conversation piece.
Build one anyway Brett!! I know you'll love it . With an FP .20 and a 9x4 APC prop, I flew it with .012 lines at 58 ft.
It very much had the feel of a Skyray, but with a little more pop in the corners.
One more thing, I highly recommend a four inch bell crank.
« Reply #14 on: May 09, 2015, 01:57:26 PM »
JIM
From your above comment, The Sig Skyray would be the PERFECT choice for you.
It builds quick, its very durable and quite capable of 500 point flights.
Start off a tad nose heavy, and as you become more comfortable with it you can slowly move the CG back to get a very smooth, responsive performance.
I know a guy here on this forum who will be more than happy to point you in the right direction on set-up and trim.
Buy and build the Skyray and you'll thank me later.
Offline REX1945
  • AMA 19945
« Reply #15 on: May 09, 2015, 02:22:42 PM »
The Sky Ray .35 is a good choice, and a lot of folks that fly with Larry have them.
Given the chance to do it over again, I would try to de-power the engine jus a tad
by either restricting the air inlet or using 5% nitro fuel. Both with a 9-4 prop.
I like the Cosmic Wind (sold as "Mass Sarah" by RSM) because it has more room for the tank
and has a tapered wing, which flies a bit better with less drag.
In any case, be sure to build with adjustable leadouts, even the Fancy Pants.
« Last Edit: May 09, 2015, 02:58:58 PM by REX1945 »
« Reply #16 on: May 09, 2015, 02:33:32 PM »
Hi Jim,
Many great suggestions!  For a profile: The Skyray 35, or a Flight Streak.
For a built up fuselage:  Combat Streak (Umland), Still Stuka, Dolphin, Mackey Bluebird, or Fancy Pants.  I have also seen a Nobler ARF do great in Classic with the .25LA.
BIG Bear
RNMM/AMM
Offline Jim Carter
« Reply #17 on: May 09, 2015, 02:43:08 PM »
Hi!  You mention the Brodak Fancy Pants; well let me assure you, it's a very nice, reliable plane.  Now as you can see there are as many preferences as there are responders but I've built, flown and thoroughly enjoyed my Fancy Pants .... even with my old 50th anniversary Fox 35 .... I've had a ball and I believe you would also.  Well, that's my suggestion.  Take care!!
« Reply #18 on: May 09, 2015, 03:25:11 PM »
  Ahem, now it's 547 (5 minutes after semi-crashing from hooking the controls up backwards). My first Skyray flight at Whittier Narrows was clearly superior to my first real stunt flight.
    My CG is now very far forward compared to what I had been using before.
« Reply #19 on: May 09, 2015, 03:29:40 PM »
Jim,
Nice Fancy Pants. Got the decal on the left, clever.
Offline JIM Nordin
« Reply #20 on: May 09, 2015, 05:05:06 PM »
Thanks for all the great advise  guys. . FedEx just dropped of the 25 so now it's time order the plane. .
I'll be ordering the fancy pants for a couple of reason . It has flaps it has landing gear in the wing I like the looks of the plane with a turtle deck and canopy
Thanks again
JIM
« Reply #21 on: May 09, 2015, 05:40:41 PM »
Ringmaster too small for an OS 25? Don't think so. They fly great on a 25 FP.
Many of that combo at the Roundup. Nothing wrong with it.
« Reply #22 on: May 09, 2015, 05:44:40 PM »
   I believe the Fancy Pants it is classic legal also, for sure N-30 if you are so inclined. I think it was a kit offered by Consolidated? I remember seeing a box for one stuffed into the basement rafters when I was a kid and could only see the end panel with the distinctive diamond logo of theirs. I have a cousin that was a member of the old St. Louis Yellow Jackets that was building and flying control line models back then, and he may have given it to one of my older brothers. It was one of those things that I wasn't supposed to touch, but I was way too short to reach it any way! I don't know what happened to it. I bought the Brodak kit when it came out just for that reason, and I also like the looks of the airplane. I built a similar looking design called "Ruby" for the first VSC I attended and it is about the same size. I'll probably use a Fox .35 on mine when the time comes, but the LA.25/FP.25 should fly this one well.
« Reply #23 on: May 09, 2015, 05:59:09 PM »
   If you run the engine at the proper speed, there's no commonly available prop that will keep it at rational lap times. I know, we tested it. Veco 19BB = 4.2 second laps, 20FP = 3.8 second laps. We didn't try the "new" 25LA, but I would expect more like 3.5. That's with an APC 9-4.
   The alternative is trying to run the engine abnormally slow, or choke it down somehow (like with an ST spraybar).
Offline Dalton Hammett
« Reply #24 on: May 09, 2015, 06:03:37 PM »
All very good suggestions for the .25.  If you decide on a profile also see the new kits available from Southridge CNC models right here on Stunthanger.   They are very nice and well priced.....
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline Jay
  • 1 Cross +3 Nails= 4 Given
« Reply #25 on: May 09, 2015, 06:33:38 PM »
If you are good at cutting ribs (I hate it) I would suggest the Ground Fault.
http://s6.zetaboards.com/Just_Fly_It/topic/8895669/1/
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
« Reply #26 on: May 10, 2015, 01:06:06 PM »
547 ?!?!?!?  I'm not surprised. Jeff Anderson always said you could put up a 500 point flight with a brick once you got the lead outs adjusted right
With the forward CG, are you using a larger stab/elevator?
The very best Skyray was Aarons second version, with a 4 inch bell crank and very slow controls, it liked the C/G around an inch aft of the leading edge.
I have all the parts cut out for a couple of Skyrays now. Should I make the stab/elevator bigger and shorten the fuse?
Offline REX1945
  • AMA 19945
« Reply #27 on: May 16, 2015, 10:53:04 AM »
Thanks again
JIM
   I had 3.5 of them. They do well with an OS .25.  Sometimes I used an APC 9-4, other times an APC 9-5.
   For a while I had a muffler with a mute and it helped with the CG location.
   I made a plug mould for the turtle deck so it could be one piece all the way back.
Rex
PS : The fuselage is sometimes a bit difficult to repair.
« Last Edit: May 16, 2015, 11:11:25 AM by REX1945 »
« Reply #28 on: May 16, 2015, 10:37:54 PM »
Any design that works well with a Fox 35 will work fine with an OS 25 LA.  Or the OS 25 FP.  Keep it light, whatever it is.
Offline Target
  • C/L Addict
« Reply #29 on: May 17, 2015, 03:35:36 PM »
This plane looks to have a wing profile similar to the Max bee -fat at the back near the hinge line- ... Is there a link for the plans download?
Chris.
PS. Good luck on the Fancy Pants, Jim. Lets see some pics along the way, if you have time?
Chris
AMA 5956
« Reply #30 on: May 17, 2015, 05:33:40 PM »
   It predates the existence of the Max Bee by something like 40 years, and this one Al Rabe really did invent, or at least discover the utility of for stunt.
« Reply #31 on: May 17, 2015, 06:06:50 PM »
 Way too small.
Uhhhh Maybe but I flew a 19 oz Ringmaster for Old Time Stunt for several years and it was an excellent flier for that event with a 10-3 or 10-4 APC prop.  (launch at 11,400 RPM with the 10-3, 5.0 second laps on 61 ft lines)
Excellent flier and very competitive.  It was also capable of very easily flying the complete PAMPA Stunt pattern.
The Sky Ray or Flite Streak are slightly better fliers but they are not OT Legal.  I also taught several people to fly and a couple of folks the elementary maneuvers in th PAMPA Stunt Pattern with the Ringmaster.
Very reliable and excellent combination and I wouldn't just dismiss it as Too Small!
PS:  As a trainer that combination has few peers!
Offline Target
  • C/L Addict
« Reply #32 on: May 17, 2015, 06:48:49 PM »
Cool, Brett. Interesting how things come full circle with regards to aero design sometimes.
Any chance you might know where to find the plans in a PDF?
Thanks either way.
Chris
Chris
AMA 5956
Offline Leo Mehl
« Reply #33 on: May 21, 2015, 08:55:27 AM »
Jerry Olsen built a warrior for his 25 LA and it flew good. Maybe even a squaw would work Or an Arctic Fox. HB~> HB~> HB~>
Offline scott ross
« Reply #34 on: May 21, 2015, 11:31:42 AM »
Hi Chris,
I have the Ground Fault plans if you're still interested.
I believe it's on Hip Pocket.
Cheers,
Scott
Offline Target
  • C/L Addict
« Reply #35 on: May 22, 2015, 05:42:29 PM »
I'm always interested....I looked on hip pocket, didn't see it. Where is it?
I'll look again.
Edit- I found it. Joined hip pocket, but am still having trouble downloading the plans.
Chris
« Last Edit: May 22, 2015, 09:18:27 PM by Chris Behm »
Chris
AMA 5956
Offline Juan Carlos Pesce
« Reply #36 on: May 22, 2015, 06:36:30 PM »
Promo 25
« Reply #37 on: May 22, 2015, 10:14:42 PM »
Promo 25
That's a very nice looking little airplane Juan.  Can you tell us what it weighs?  Is it kitted by anyone or are plans available for it?
Thanks for sharing it,
Offline Target
  • C/L Addict
« Reply #38 on: May 23, 2015, 01:20:11 AM »
The plans are the last attachment that doesn't have a thumbnail picture.
R,
Chris
Chris
AMA 5956
Offline Luiz Ribeiro
    • Ribeiro's Home Page
« Reply #39 on: May 23, 2015, 02:13:09 AM »
Randy,
I agree, it's a very nice plan. There is a pdf file listed below Juan's second photo with a plan. You can download it.
Regards.   Luiz
« Reply #40 on: May 23, 2015, 08:25:59 AM »
Hi Randy.
While the model was designed by an Argentine, the kit is manufactured and marketed in Brazil. Maybe Luiz can give more information.
I have no information on weight.
You can see a construction tutorial on:
http://s6.zetaboards.com/Just_Fly_It/topic/8877730/1/
regards
Juan Carlos Pesce
Buenos Aires
Argentina
« Reply #41 on: May 23, 2015, 11:33:59 AM »
Just came back from reading the posts on your construction and the flying plus rebuild.   Really nice looking plane to take out and just fly.
« Reply #42 on: May 23, 2015, 11:45:49 AM »
Thanks Chris, Luis, and Juan.
My old eyes missed the PDF file.  Nice plan but it doesn't seem to have any scale size reference on it.
A friend of mine is looking for something a little different to build for his second CL airplane and I thought this one might appeal to him.
« Reply #43 on: May 23, 2015, 11:50:05 AM »
Randy, you need new glasses.   There are deminsions of wood sizes on the plans to work with.  Yes I have to pick on the old man. S?P
Offline Bill Smith
« Reply #44 on: May 23, 2015, 01:02:32 PM »
Brodak .25 on an S-1.
Flies great.
Fancy Pants is also great.
« Last Edit: May 23, 2015, 03:14:10 PM by Bill Smith »
« Reply #45 on: May 23, 2015, 06:45:49 PM »
Yes Doc,
But, a small measuring error at 1/4 inch becomes a large error at 40 inches.  It's always better to have a scale reference rule when scaling up a small drawing.  Unless of course you're a really OLD man like one of my friends and don't care!!!  y1 <=
