  • July 04, 2025, 07:32:26 PM
Author Topic: Glow Plug Starter  (Read 645 times)
Offline scott matthews
Glow Plug Starter
« on: August 17, 2013, 02:57:52 PM »
I have a Sonic Tronic charger that the metal shaft is coming loose from the handle. I believe this is causing a short, I noticed this when I went to charge it the light on the wall unit flickers off and on when I wiggling the metal shaft. I would like to know if it is possible to cut off the rubber coating on the handle to repair this, and what do you use to replace the orange rubber on the handle with?
Offline Clancy Arnold
Re: Glow Plug Starter
« Reply #1 on: August 17, 2013, 08:31:36 PM »
Scott
I did an article on repairing Glow Plug Igniters that was in the April 2013 Model Aviation.  Hope it helps you.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #2 on: August 18, 2013, 06:15:58 AM »
The rubber cover is just a pair of caps that meet in the middle.  Peel off the yellow tape in the middle, and slide the cap off.  Then you can resolder the shaft to the battery.
« Reply #3 on: August 18, 2013, 05:15:00 PM »
Thanks Andrew , popped of the two covers this morning and soldered the tip back on. Working as good as new if not better.
