  • July 08, 2025, 05:07:07 PM
Author Topic: GHQ part needed  (Read 2173 times)
Offline Marvin Denny
GHQ part needed
« on: December 03, 2012, 01:52:40 PM »
  Gentlemen--- I am in need of the point assembly for the old GHQ engine.
  Any help out there?
  Bigiron
marvin Denny  AMA  499
Offline John Cralley
Re: GHQ part needed
« Reply #1 on: December 03, 2012, 03:51:24 PM »
Marvin,
Sorry, I can't help with parts but I have (Not so fond) memories of the old GHQs. That was my first engine back in the 1940s and I could not get enough power out of it to fly an airplane.
Recently, I was told that the GHQ would run in either direction but was basically setup to run clockwise (as seen from in front). That might explain the lack of power since I was running it counterclockwise.  HB~>  Do you know if that is correct??
John Cralley
AMA 52183
Central Illinois
Offline Andrew Borgogna
  • Andy
Re: GHQ part needed
« Reply #2 on: December 03, 2012, 06:19:38 PM »
Give Woody a call that the following web site.
http://www.woodysengines.com/about.htm
Woody knows everthing there is to know about ignition engines, what he doesn't have he can generally make.
Andy
Andrew B. Borgogna
Re: GHQ part needed
« Reply #3 on: December 04, 2012, 02:58:20 PM »
Motorman is correct.  The points can rotate 360 deg., so you can set it to run in either direction.  A 3-port design, it will run exactly the same in either direction, since the port timing is the same.
I had a GHQ which actually did run, but not very well.  The original Loutrel engine was well made and worked in tether cars or boats (too heavy for an airplane).  The production was taken over by AHC and they only made 1 or 2 good ones for every 100 they sold.  If the parts accidentally fit, then it would run.
Re: GHQ part needed
« Reply #4 on: December 04, 2012, 03:31:47 PM »
I understand that there's folks out there who rebuild them with decent fits & finish, and go flying.
I guess you can tell if one is rebuilt, by the fact that it'll actually run...
Re: GHQ part needed
« Reply #5 on: December 04, 2012, 07:25:38 PM »
Once I was at the Sierra Eagles field near Rancho Cordova, CA, for an FAI FF contest. Some guy was there before the contest started, flying a Sal Taibi "Powerhouse" (a very large cabin model) with a GHQ and R/C. Bill Wisnewski had "rebuilt" it for him (probably for lotsa $$$) and it hauled that Powerhouse pretty much straight up. It's wonderous what money can accomplish...look to our goobermint for a shining example.  D>K Steve
Re: GHQ part needed
« Reply #6 on: December 05, 2012, 11:54:39 AM »
I have Woody's "Aero Electric" catalog.  I can provide part numbers and prices if you know what parts are needed.
Re: GHQ part needed
« Reply #7 on: December 05, 2012, 08:13:43 PM »
  Thanks guys,.  I have gone to Woodies site and didn't see any GHQ point sets  listed.  But that doesn't mean that he don't make them.
  I am asking as a favor for a fellow modeler here in my area so I'll ask him how much he wished to spend.
  Thanks Floyd, I'll keep you in mind if he wishes to proceed further in restoring his GHQ.  The entire point mechanism is missing.
  bigiron
Re: GHQ part needed
« Reply #8 on: December 05, 2012, 11:14:25 PM »
Hi Marvin,
Here's the page from the Aero Electric catalog #9 (a couple years old) with the GHQ parts listing.
Re: GHQ part needed
« Reply #9 on: December 06, 2012, 08:24:54 AM »
Marvin,
Here is a link to the AeroElectric web site.
http://www.woodysengines.com/assets/pdfs/informational.pdf
John Cralley
AMA 52183
Central Illinois
Re: GHQ part needed
« Reply #10 on: December 06, 2012, 03:06:29 PM »
  Thanks for all he assistance guys.  I have been in contact ith Woodies engines.   All is well.
  Thanks again
  Bigiron
