  • July 16, 2025, 09:15:04 PM
Author Topic: Generator for the NW Regionals  (Read 1147 times)
« on: May 26, 2011, 01:54:53 PM »
Does somebody have a 115V generator that puts out at least 1000 watts that we can use at the stunt circle?  It would greatly reduce the workload for Scott and his crew.
Howard
Online Tim Wescott
Re: Generator for the NW Regionals
« Reply #1 on: May 26, 2011, 02:17:21 PM »
I thought cattle prods were battery powered.
« Reply #2 on: May 26, 2011, 02:22:12 PM »
We have special cattle prods that shoot ball lightning at slow-moving contestants' ... well, that's why they call it ball lightning.
« Reply #3 on: May 26, 2011, 04:39:17 PM »
You would be welcome to use my 4K but I've been running it a lot lately to allow my sump pump to run every 15 minutes!!  Why does our power always go out at night instead of when I don't want to sleep!? HB~> HB~> ''
Online Tim Wescott
« Reply #4 on: May 26, 2011, 06:18:43 PM »
I'm in trouble then -- all my engine runs seem to either end in the middle of a loop, or run on well past the end of the pattern.
Offline Derek Moran
« Reply #5 on: May 28, 2011, 08:43:06 AM »
Dan has a Honda generator.  Actually, he has a Honda and an inverter.  The inverter has sufficient capacity to power a MonoKote iron which ought to be fine for your *new* printer.  The whole setup is not much bigger than a dedicated gas generator.  An added advantage is you don't have to push it to and from the ED's tent.
Derek
AMA 82617
