  • June 27, 2025, 12:39:58 PM
Author Topic: fuel tank  (Read 2109 times)
Offline Bootlegger
fuel tank
« on: March 13, 2014, 11:01:13 AM »
 Fellow's I am looking for a clunk tank for profile models that is about 3 oz cap, and has a "tongue" on the side, and has two vent lines and an opening for the clunk.
 I have used them on R/Master and other 25 powered models, but can't find the Mfg or a model # to order some more.
 If y'all can help, I sure would appreciate it...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Ward Van Duzer
Re: fuel tank
« Reply #1 on: March 13, 2014, 11:22:08 AM »
It might help if we knew weather or not you're talking about a plastic tank or a metal one. A sketch might help also! It kind of sounds like you're talking about a "chicken hopper", but maybe not....
W.
Offline Dick Pacini
Re: fuel tank
« Reply #2 on: March 13, 2014, 11:38:44 AM »
AMA 62221
Re: fuel tank
« Reply #3 on: March 13, 2014, 11:42:36 AM »
Offline Bootlegger
Re: fuel tank
« Reply #4 on: March 13, 2014, 12:47:12 PM »
 I knew when I posted that request that y'all would come thru for me ... Kraft Hayes is a BINGO, blanked out the card..
   Again thanks ...
Gil Causey
AMA# 6964
Online Harold Brewer
Re: fuel tank
« Reply #5 on: March 13, 2014, 01:22:11 PM »
Yes - It is a Hayes 3 oz. plastic clunk tank.  I just ordered three of them from Omni; currently on backorder and expected to arrive sometime in mid March.  Same situation at Tower.  Interestingly, both outlets have plenty of the Hayes 4 oz. tanks.
Brew ;D
Re: fuel tank
« Reply #6 on: March 13, 2014, 03:52:23 PM »
Gil,
You might want to do a search on this forum for the FP20 setup. Brett found a very reliable tank setup using the Hayes tank.
Best,      DennisT
Re: fuel tank
« Reply #7 on: March 13, 2014, 10:10:23 PM »
Gil,
Best,      DennisT
   That would have been The Dirt, not me. I have run it and it works fine, but Dan pioneered it. I use(d) a Sullivan ss-4.
Offline Perry Rose
Re: fuel tank
« Reply #8 on: March 14, 2014, 04:37:04 AM »
Get the 4 ounce Hayes tank. It only holds 3.5 ounces anyway. I have several and they work fine converted to uni-flow.
