  • August 05, 2025, 12:44:01 AM
Author Topic: fuel tank stock  (Read 2222 times)
Offline Bootlegger
fuel tank stock
« on: September 02, 2015, 08:27:37 AM »
  Guy's I am looking for some tank stock in these demintions, .007 thick and 12"x12". K&S stock is great, but only comes in 4"x10" sheets,, and some time I need more..
 Any help will be appreciated...
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Tim Wescott
Re: fuel tank stock
« Reply #1 on: September 02, 2015, 08:46:39 AM »
They have 0.008 x 6 x 12.  There's three sheets sitting on my bench that I just got from Tower.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUTU8&P=ML
Re: fuel tank stock
« Reply #2 on: September 02, 2015, 10:46:28 AM »
Eric Rule (RSM) sells tank kits, if that works for you. Alternatively, you might ask at auto body shops for their gallon reducer cans...and they'd probably be happy to see them gone. Or, use your own empty gallon cans. And, of course, you can get what you want from McMaster-Carr. H^^ Steve
Online Tim Wescott
Re: fuel tank stock
« Reply #3 on: September 02, 2015, 10:53:22 AM »
My latest set of empty Powermaster fuel cans has some sort of varnish on the inside, not tin-plate.  Sigh.  Once again, technology leaves us behind.  Perhaps I should build a tank out of carbon fiber...
Offline John Park
  • Agricola
Re: fuel tank stock
« Reply #4 on: September 02, 2015, 12:19:31 PM »
Hmm...  Way back, somebody gave me a roll of .002" copper foil.  I've wondered about making a tank out of that, and cladding it in a few layers of carbon veil or glass cloth and epoxy for rigidity - or even 1/8" balsa, like the Dutch combat fliers do.  Should work...
Re: fuel tank stock
« Reply #5 on: September 02, 2015, 08:15:18 PM »
For tanks I use the .008 thk tin plate from K&S in the 6 x 12 sheets.  A rectangular tank 5.0" long X 2.0" wide X 1.25" high gives 6.93 oz, more than enough for most applications.
Need more, 6.0" long X 1.75" wide X 1.25" high yields 7.27 oz.  Still More?  6.0" long X 2.0" wide X 1.25" high gives 8.31 oz.
If you need a real bathtub you can make the height of that one 1.375" and get 9.14 oz.
You can cover just about any requirement using the 6" wide stock and a little arithmatic.  Or my spread sheet program since I'm lazy.
Re: fuel tank stock
« Reply #6 on: September 03, 2015, 05:45:53 AM »
Brodak has tank stock because Brodak makes custom tanks. They made a great one for me.
I have no idea how thick the stock they use is?
Offline Phil Krankowski
Re: fuel tank stock
« Reply #7 on: September 03, 2015, 06:39:36 AM »
I have olive oil cans.  Need washed first but work fine.  Crown and Kleen Strip cans are tin inside and out last I checked, same with Coleman fuel.  Of course all of these need the paint stripped off before you are ready to solder.
Phil
Offline Bill Johnson
Re: fuel tank stock
« Reply #8 on: September 03, 2015, 07:49:39 AM »
I'd think it's the .008" stock. The next size up is .016" and that's pretty thick and would be tough to form end caps.
Best Regards,
AMA 350715
Online Tim Wescott
Re: fuel tank stock
« Reply #9 on: September 03, 2015, 10:10:07 AM »
How ambitious are you?
http://tinplates.com/
Offline Clancy Arnold
Re: fuel tank stock
« Reply #10 on: September 03, 2015, 07:04:26 PM »
Many years ago I bought a roll of .005 phosphor bronze shim stock at a surplus store. It measured 6 In wide and over 3 Ft long.  I have built several tanks and I still have about half of it left.  In a Super Ringmaster I replaced a 2 ounce "Perfect" wedge with a 4 ounce rectangular tank that weighed less.
Clancy
Clancy Arnold
U/Tronics Control
Offline RC Storick
Re: fuel tank stock
« Reply #11 on: September 03, 2015, 07:33:54 PM »
Do not sticky this item again
Re: fuel tank stock
« Reply #12 on: September 03, 2015, 09:51:25 PM »
Huh???  What Does that mean?
Online Tim Wescott
Re: fuel tank stock
« Reply #13 on: September 03, 2015, 10:56:43 PM »
Someone pinned it to the top of the forum earlier today (I didn't know you could do that if you weren't a moderator).  Robert (I assume) doesn't feel it warrants being so pinned.
Offline Bootlegger
Re: fuel tank stock
« Reply #14 on: September 04, 2015, 03:15:52 PM »
 Guy's I sure do thank all y'all for the suggestions as to where I can get the tank stock, got some ordered and I just wanted to say THANK'S... H^^ H^^
Gil Causey
AMA# 6964
