  • May 31, 2024, 10:16:35 PM
Author Topic: My New Sakitumi Glow Power  (Read 6603 times)
Offline badbill
« on: January 07, 2018, 09:41:51 AM »
About a year ago I finished my Sakitumi Electric, and it has become my go to plane in all respects. See here- https://stunthanger.com/smf/open-forum/builtright-flyright-sakitumi-e/msg507748/#msg507748 I decided not long after that it would be cool to have a glow powered version also, and put in my order with Walter. Not too long after, I got the kit. While other projects had to be cleared out,it was always in the back of my mind and about a month ago I cleaned off the bench and went for it. Just like the electric, it was a pleasure to build. Factory OS LA-S .46, APC 12.25x3.75 prop with a custom cut Dave Brown spinner. All iron on covering, rustoleum rattle can for the LG and wheel pants. Weight is 1 ounce less RTF than the E Version RTF. Balance is perfect. Can't wait to fly it!
Bill Davenport
AMA 28141
Offline Allan Perret
  • Proverbs
Re: My New Sakitumi Glow Power
« Reply #1 on: January 07, 2018, 09:55:50 AM »
Nice, tell us about your gear struts.  Is the Sakitumi and inline design ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Chris Fretz
« Reply #2 on: January 07, 2018, 10:02:58 AM »
I like it.  What kind of fuel tank is that?  Could you show pictures of your tank mount as well?
Chris
Formerly known as #Liner
AMA 1104207
Advanced
Offline badbill
« Reply #3 on: January 07, 2018, 11:04:06 AM »
Chris
Thanks guys. It's a Kraft/Hayes 6 oz tank. I'd show you pics of the tank mount, but it's kinda covered up by the tank. It is two rectangles of thin G10 fiberglass with separator pieces for the tie wraps to go through. The slots on either end allow it to be adjusted up and down. Allan, the Sakitumi was designed by Elliott Scott. The landing gear comes with the kit, I got the machine shop guy at work to put lightening slots in it.
Bill Davenport
AMA 28141
Offline Target
  • C/L Addict
« Reply #4 on: January 07, 2018, 11:25:20 AM »
That looks great Bill. Are you using the hobby king coverings?
Chris
AMA 5956
Offline badbill
« Reply #5 on: January 07, 2018, 11:39:40 AM »
The Red one is HK covering, the Green one is Ultrakote and Monokote. All work well, IMO.
Bill Davenport
AMA 28141
Offline BYU
« Reply #6 on: January 07, 2018, 12:37:47 PM »
Its an in-line design. A derivative full body version is on my building table right now.
« Reply #7 on: January 07, 2018, 12:40:50 PM »
   That's the name he gave us, at least.
Offline Larry Fernandez
« Reply #8 on: January 07, 2018, 01:47:23 PM »
Yes, Elliott Scott.
Man of mystery
Larry, Buttafucco Stunt Team
  • Proverbs
« Reply #9 on: January 07, 2018, 01:50:26 PM »
Will this one have flaps, going to be a competitive PA stunter ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #10 on: January 07, 2018, 02:00:41 PM »
   It's a competitive stunter as it is. I have a 560 score to my credit with mine. And I finished 8th! But only about 20 points off the podium.
« Reply #11 on: January 07, 2018, 05:18:24 PM »
Yes, Elliott Scott.
Man of mystery
   Once, I overheard him answer the phone using the name "Race Bannon".
« Reply #12 on: January 07, 2018, 05:28:05 PM »
I still don’t understand how he can be spotted in four different places, around the world, at the same time.
A man of mystery indeed!
Offline BYU
« Reply #13 on: January 08, 2018, 12:16:42 PM »
2 versions, one flapless and one with flaps - Both using current moments and airfoils.
Offline badbill
« Reply #14 on: January 09, 2018, 12:01:54 PM »
The more I look at these pictures, the more I think I gotta go back and put the white on the wingtips of the red one... gotta get on that tonight. Would be nice if the weather would clear up enough to fly either one this weekend  #^
Bill Davenport
AMA 28141
Offline Target
  • C/L Addict
« Reply #15 on: January 09, 2018, 01:35:26 PM »
Agree 100% Bill.
Chris
AMA 5956
Offline badbill
« Reply #16 on: January 09, 2018, 05:45:08 PM »
Aaaannnnddd there ya go. Man, if you haven't tried the monokote trim solvent, run don't walk to your nearest tower hobbies. It IS the shizz.
Bill Davenport
AMA 28141
Offline Chris Fretz
« Reply #17 on: January 09, 2018, 06:14:42 PM »
What does trim solvent do?
Is this airplane consider a precision aerobatic airplane?
AMA 1104207
Advanced
Offline Target
  • C/L Addict
« Reply #18 on: January 09, 2018, 07:27:13 PM »
Allows layers of film bonded without heat, and therefore without bubbles.....
« Last Edit: January 09, 2018, 08:11:53 PM by Target »
Chris
AMA 5956
Offline badbill
« Reply #19 on: January 09, 2018, 07:48:02 PM »
Allows layers of film bonded without heat, and therefor without bubbles.....
Yes, for monokote on monokote. Make no mistake, as with everything there is a learning curve, but it is great stuff.
Bill Davenport
AMA 28141
Offline Walter Hicks
« Reply #20 on: January 10, 2018, 12:05:02 PM »
Elliott Scott is the original designer and is well aware of what it takes to make this airplane fly well flaps or no flaps.  :)
Offline dennis choate
« Reply #21 on: January 10, 2018, 01:38:42 PM »
Years ago Roy Tranthom gave me one to fly.  had a double star 50 and it flew incrediably well without flaps
Offline BYU
« Reply #22 on: January 10, 2018, 03:23:52 PM »
I would think adding flaps would require a radical redesign of the wing structure.
The Sakitumi flies an excellent pattern “as is” without flaps and its airfoil is designed with a very forward high point to ensure it doesn’t need them (the airfoil is inspired by full size aerobatic plane designs NACA 0016).
My old prototype Sakitumi has taken me up the ranks to first and second places. I use an LA 46 with 12.25 x 3.75 Prop, but a good 40 with a smaller prop will fly it well. If you can use a smaller prop than the 12.25 x 3.75 the corner improves even more than the “blinding” one a Saki can already do.
Walter Umland kits the design and also makes a 25 version for the LA 25, which I hope he will make more public (hint, hint).
« Last Edit: January 14, 2018, 05:40:56 PM by Bobs your Uncle »
Offline badbill
« Reply #23 on: January 29, 2018, 09:15:31 AM »
Well, I got it out yesterday. Only got in one flight then the rain started, but damn it is awesome! Flies great, needs very little adjustment. I took a little weight out of the wingtip when I got home, and next time out I may move the leadouts forward a touch. It pulls pretty hard, but it isn't uncomfortable. Power is pretty similar to the electric. I am tickled with it!
Bill Davenport
AMA 28141
Offline John Rist
« Reply #24 on: January 29, 2018, 10:30:13 AM »
Is it a written rule that all Sakitumi must be covered in clear?  I know I did!    LL~   LL~   LL~
Offline Jim Svitko
« Reply #25 on: January 29, 2018, 10:53:47 AM »
The Sakitumi reminds me of the Teosawki.  To me, the Sakitumi is more visually appealing.
Offline badbill
« Reply #26 on: January 29, 2018, 12:52:01 PM »
The Sakitumi is a newer version of the Teosawki , hence the play on words with the name.
Bill Davenport
AMA 28141
« Reply #27 on: January 29, 2018, 06:38:18 PM »
Yes the clear covering shows off the great laser cut parts   If I didn't already have so many projects I would get one.  Especially after seeing Dan McEntee's version fly. H^^
Offline badbill
« Reply #28 on: February 07, 2018, 08:24:36 AM »
I got in 8 flights on the glow version yesterday and had a BLAST, it is just delightful. Gotta say the LA 46 is a gem, starts and runs like a champ.
Bill Davenport
AMA 28141
Offline Peter Nevai
    • C3EL
« Reply #29 on: February 07, 2018, 09:44:23 AM »
Very Nice, but seriously dude that pool needs attention.
Offline baum58
« Reply #30 on: July 22, 2019, 02:50:05 PM »
hello to all,
Just started to fly again. I am a glider guy.   For the elevator flaps and aileron's we use sealed hinges, no air can bleed  between the elevator (in this case) and the hinged part, and is therefor more deficient. Could this be used in a u-control?
Peter
« Reply #31 on: July 22, 2019, 07:49:25 PM »
hello to all,
Peter
   Hi Peter;
    I am a former glider guider, and we not only seal our hinge lines, there are several threads about the best types of tape to use. Try using the search function for that and see what you find.
Offline Carl Cisneros
« Reply #32 on: July 22, 2019, 11:10:59 PM »
no, they do not have to be covered in transparent film.   VD~ VD~
Carl R Cisneros, Dist IV
Control Line RB
Offline builditright
  • So happy to be alive!
« Reply #33 on: July 23, 2019, 12:00:18 AM »
Hi John, I don't think anyone has set up any rules that all Sakitumi's have to be done in clear or transparent covering/colors. But you sure do have to admit they really do look so cool and it sure is nice to see the cleanly constructed wing.
Oh B.T.W... John, can you please send me some pictures of yours for my website.
Thank you and God Bless
Walter
aka/ builditright
Offline Mike Alimov
« Reply #35 on: July 23, 2019, 03:07:12 PM »
I ran.  Tower Hobbies does not list Monokote Trim Solvent.  Put word "solvent" in their search and you get nothing.  Also not listed under Covering Accessories.  Where did you get yours? (Unless it was 20 years ago..)
Offline ray copeland
« Reply #36 on: July 24, 2019, 03:04:45 AM »
Try using acetone, I believe that is all trim solvent is. ;)
Offline badbill
« Reply #37 on: July 24, 2019, 10:26:06 AM »
I made that post in January of 2018, and had got the trim solvent from Tower Hobbies that week.  I don't know if acetone will work, it smells nothing like acetone.
Bill Davenport
AMA 28141
Offline BYU
« Reply #38 on: July 24, 2019, 11:23:08 AM »
Bill you did an awesome job with both versions.
Looks really good in red, I think I need one myself in red.
Offline Fredvon4
  • Central Texas
« Reply #39 on: July 24, 2019, 11:44:57 AM »
Topflite as a brand is all but dead....no more models, arfs, kits, monokote, trim strips, solvent....all gone---- only remaining stock at folks like Graves RC...etc....
bottle of Top Flite MonoKote Trim solvent sez: cyclohexanone dihydro 1(3H)-furanone and petroleum hydrocarbon
too lazy to seek the MDS ....but not Acetone, MEK, or Xylene....I seem to recall one forum claimed it was actually a Nitro Methane / or Ethane derivative but I am no chemist....perhaps raw nitro does work...dunno
Fred von Gortler IV
Offline badbill
« Reply #40 on: July 24, 2019, 12:25:22 PM »
Thanks, they are both still flying and doing great. It's a real fun build and I love the way they fly.
Bill Davenport
AMA 28141
Offline Doug Moon
« Reply #41 on: July 25, 2019, 04:14:41 PM »
Is there a kit of this thing.  Looks like a real fun rig!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Target
  • C/L Addict
« Reply #42 on: July 25, 2019, 04:27:44 PM »
Walter Umland sells kits of this plane.
Chris
AMA 5956
« Reply #43 on: July 25, 2019, 09:48:50 PM »
The resurrection of this old thread has reminded me of how much we all miss Allan Perret, and now the late great Bob's Your Uncle. Dammit, Jim!   y1 Steve
Offline BYU
« Reply #44 on: July 29, 2019, 06:49:32 PM »
“The reports of my death are greatly exaggerated.”
Bob's Your Uncle
Online Mike Scholtes
« Reply #45 on: July 29, 2019, 08:06:47 PM »
I've built both the 46 and 25 size, from Walter Umland's excellent kits, and can recommend them highly, despite the demise of the designer, who obstinately continues to deny being deceased.
Offline Target
  • C/L Addict
« Reply #46 on: July 30, 2019, 11:26:49 PM »
... despite the demise of the designer, who obstinately continues to deny being deceased.
"Shoot 'em again, Pah, he's still twitchin'!" VD~
Chris
AMA 5956
