What I do is tack glue the two pieces of 1/4 square, or whatever, together with enough overlap. Then I cut them apart with a Zona saw, and pop the glued on ends off. As long as they are held steady and the saw doesn't bend, they will glue together perfectly. My recollection is that a proper scarf joint is supposed to be 12 to one. Mine aren't that good.
