  • June 29, 2025, 09:29:57 PM
Author Topic: Skywriter  (Read 1998 times)
Offline peabody
Skywriter
« on: November 05, 2007, 08:48:36 PM »
Is that the name of the Chinese WC plane? Didn't someone make plans and kit it?
Re: Skywriter
« Reply #1 on: November 05, 2007, 10:43:28 PM »
One of. Yes.  LL~ Steve
Offline Kerry Ewart
Re: Skywriter
« Reply #2 on: November 06, 2007, 01:29:53 AM »
Try:-http://www.tanks-hangar.com/index.html and look under stunt then esp kits also contact Steve hand via this site.
"If you cannot beat them!JOIN THEM.
Re: Skywriter
« Reply #3 on: November 06, 2007, 01:23:44 PM »
And it is basically the same plane that the Chinese are still flying.  Sorta like Ted's *****mitaion/Final Edition series.  Pretty much the same aerodynamics, at least when they were at the 2004 World's.
Offline Bob Zambelli
Re: Skywriter
« Reply #4 on: November 06, 2007, 01:29:04 PM »
What did the Chinese use for power?
Re: Skywriter
« Reply #5 on: November 06, 2007, 01:47:44 PM »
Xhaing used a ST 60 (or Chinese clone) in the Skywriter.  The 2004 World's saw the Chinese using 4 strokoes (at least the top two).  Xing Ping (sp??) was using a Saito Golden Knight 56.
Offline Mike Ferguson
Re: Skywriter
« Reply #6 on: November 06, 2007, 02:39:58 PM »
Yep - that's the name of the Chinese Worlds plane.
There's a few sources for the plans.  The most accurate set (IMHO) can be obtained at the link below from the designer himself, Mr. Arden Zhang.
http://www.ajhobby.com/
Pretty interesting stuff.  It shows a "slanted" tank design (similar, I believe, to what Brett Buck uses) and really small, quick controls.  The bellcrank's smaller than three inches, and the horns are pretty short, too.
Re: Skywriter
« Reply #7 on: November 06, 2007, 09:48:35 PM »
HI Mike,
The only differences I could *see* at the 2004 between the original Skywriter and the planes the Chinese team were flying were cosmetic.  They looked like Yak fighter planes, etc.
