  • July 17, 2025, 05:39:50 PM
Author Topic: Foam through a laser cutter  (Read 1187 times)
Offline Shorts,David
« on: July 24, 2021, 08:58:27 AM »
Can you run Lowes 1" thick blue foam through a laser cutter?
Re: Foam through a laser cutter
« Reply #1 on: July 24, 2021, 04:19:06 PM »
    I would make an uneducated wild ass guess that you could, you just have to adjust for power and speed of cut and go like mad!!If available, I think a water jet may be a better choice and even with that you would need to make major adjustments in pressure and speed.
Offline Perry Rose
« Reply #2 on: July 25, 2021, 05:16:29 AM »
The laser beam spreads out a lot at 1/2 inch thickness, one inch is too much.
Online Mike Alimov
« Reply #3 on: July 25, 2021, 07:20:44 AM »
I would suggest hotwire using Formica templates.
Offline Istvan Travnik
« Reply #4 on: July 25, 2021, 03:23:15 PM »
Hotwire,
heated by laboratory supply unit, anyway.
Current adjustable in mA, voltage in 1/100 V steps. A 5A / 30V capable unit is fully satisfactory.
Istvan
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #5 on: July 25, 2021, 06:40:33 PM »
So I know the Flite Test guys use a laser or foamboard, and foam inserts in toolboxes are often cut with a laser.
I think it would work, but the focus on the laser may be different for thick foam.
https://kernlasers.com/applications/foam/
Dave Siegler
NE9N extra class
AMA 720731
