  • July 18, 2025, 10:40:57 AM
Author Topic: Flying on Water  (Read 14421 times)
Offline Chris Fretz
Flying on Water
« on: July 13, 2016, 07:14:42 AM »
Anyone ever try flying in the middle of a fairly shallow Creek or River? Do you think you could stunt with pontoons?
Formerly known as #Liner
AMA 1104207
Advanced
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #1 on: July 13, 2016, 07:53:14 AM »
That is something I've wanted to try also. I wanted to get this kit from hobby people to try it out by converting it to CL. Also, from my rc days, I know you can spray pam on the pontoons and fly off grass just as easy!
http://www.hobbypeople.net/index.php/miss-orleans-seaplane-ep-gp-wood-airplane-kit.html
Offline Chris Fretz
Re: Flying on Water
« Reply #2 on: July 13, 2016, 08:38:28 AM »
We can do this LL~  I wanted to slap some pontoons on a beat up Estes Ringmaster an try it. Just don't know where to get some cheap light pontoons.
« Last Edit: July 25, 2016, 07:12:32 PM by #Liner »
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #3 on: July 13, 2016, 08:41:21 AM »
Wow that thing is big, I guess if your going to do it go all out right!
AMA 1104207
Advanced
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #4 on: July 13, 2016, 09:29:28 AM »
Offline Chris Fretz
Re: Flying on Water
« Reply #5 on: July 13, 2016, 09:57:57 AM »
AMA 1104207
Advanced
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: Flying on Water
« Reply #6 on: July 13, 2016, 10:09:41 AM »
Back around 2000 at the NW Regionals (roseburg, Oregon) there was a CL float pond created and we hosted several events at the site. It was a 180 degree arc of water and we flew everything from large CL scale models to stunt models with floats. We even flew 1/2a models with floats and then my 80" Piper cub had floats on it. at one point we had 14 planes with floats on it at the site.
It is very possible but a river that is moving would be a problem. If you were on the lakeshore that had clearance along the shoreline that would be best. 1/2 over water, the 1/2 over land. Landing gets tricky because you need to land on the water unless you want to refinish your floats.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Chris Fretz
AMA 1104207
Advanced
Offline John Park
  • Agricola
Re: Flying on Water
« Reply #8 on: July 13, 2016, 10:13:24 AM »
How about this? http://www.outerzone.co.uk/plan_details.asp?ID=3751
I suppose some sort of three-line system for throttle control must still exist for Carrier flying.
Offline Chris Fretz
Re: Flying on Water
« Reply #9 on: July 13, 2016, 10:14:16 AM »
Fred
How heavy were your floats for stunt?
AMA 1104207
Advanced
Re: Flying on Water
« Reply #10 on: July 13, 2016, 10:57:13 AM »
Of Course ya can . Here 1999 , original floats . ( couple of Tornado 10-6s on it there , rh & lh )
71 Torpedo 40 , unmuffled , a 11 x 5 , 63 ft. of .016 solids . Cept Ive Tarted it up , & as a OS  H40S is the same Wt  muffled it s in just now .
4055 abc K&B in it below , Sould keep that - For Musswellbrook . Its held ' in the sticks ' & those Dyna Jet Blokes turn up , too .
« Last Edit: July 13, 2016, 12:17:14 PM by Matt Spencer »
Re: Flying on Water
« Reply #11 on: July 13, 2016, 11:12:13 AM »
In Fact , in dream air , you wont find a more deadly accurate Aeroplane . ( Id just look at you as if you rode a CB 750 rather than laughing in your face , if you thought not ) .
Wind starts at 7 knots to introduce a lateral weave , due to the Fwd. Side Area . Floats There are more bouyant than the Original ( Sat at a scale loaded ' Sit '  Rear Strut Was Waterlevel , noses out )
Fine for Calm Water - But The Sharks Bite in a chop , and tryn pull them under - so a tip takes a time to rise . But as its a chop Someone Needs to Grab it fairly Smartly .
A Tip . If Its a Tidal River , your DOOMEd , even though saltwaters more bouyant . I landed it inverted with the FSRS in it at Whitianga years back . Open Cockpit . New Pushrods have got rid of the ruist . C R C the Lines .
Fresh Water would provide lower maintanace . Lacquer the Control System .
Same Wt. now as when built . Only had it in the Air twice ,. Since rebuild , I think. Not in ahurry  Concieved  70's . Built 1999 , Flown Nowra 2000 . Briefly . Repeatedly in N.Z.
 With the 71 Torp. Thats a 4055 in the pictures , here .
If its NOT as Good as it was . The Narrower Floats will be fitted . Flew of the Orewa Estuary With Them , Ride on a Canoe to the Mud Flats & a launch . Two Flights . Had to swim back ! .
Is Airworthy at the moment . But wannabe on the ball . Had a runnawayon the Torp at Dusk - Does about 90 mph . in the dark . and YOUR inverted ( as it were ) OPENING the Needle From 1 7/8 turns To One Turn, not TWO !
tthat good Enya needles GONE too , Sat Flush , Hollow End , Cut a Notch & used a srew driver . Needed Opening . Suppose I mustve Turned it IN 1 7/8 then opened it 2 Halves ( 2/2 ) when someone gabled . NO Distractions .
Please .
« Last Edit: July 13, 2016, 12:15:23 PM by Matt Spencer »
Re: Flying on Water
« Reply #12 on: July 13, 2016, 11:16:30 AM »
Found this yesterday ( last night )
The Purple and White plane is a Sig Magnum C/L converted to ROW (rise off water).It is a joint effort by Nils Norling
Online Larry Renger
Re: Flying on Water
« Reply #13 on: July 13, 2016, 11:23:28 AM »
Cox put out their small Piper Cub with floats and skis. We demo'd it at the Nats one year.  ;D
Re: Flying on Water
« Reply #14 on: July 13, 2016, 11:23:54 AM »
To cut a long story shorter , 71 Top 40 & warp , Bit of Inverted , first gfo , cut on turn to upright .
Second Go , Caught Fire up in the Ex Ducts Engine Bay . Shirt of & Wrap while a 11 Yr Old Rhodesion Spints 100 Meters for WATER .
Was Encouraged when He Slowed near back , seeing it out . By Then . I needed it For My Hands . But 5 weeks work Ya dont let go easy .
SO , Later . The G 51 Back In one friday evening , after a few weeks on a backward version of a japanese version Of Bob gieskes Version Of George Aldriches  :P Nobler . (Not KNOBLA thats Austrwlyen )
Silent Muffler . Balanced Well . Full schedule , ( we have ) Fuel over and the winds eased  ( and Swung 160 Degrees ! Unbeknowst ) a Repeat Horizontal Eight , at altitude , to seaward !  :o
A GUST Come Through ( Thru ) as it hits the intertsection going upward ( after one cycle ) and Kicks it IN a way . Dumb with shock , ' we ' stand . dazed and bewildered , about the time Ive figured where to run,
Opposite to normal , just about . or a few things are , at least . in two seonds ( or less ) its Flown Itself OUT Tight . ( was kicked over 30 degrees & 10 Ft ' IN ' slack .  %^@
The Inner Wing is 1 3/4 longer . With Good Reason .
The Swine Flys CLOCKWISE . With good reason . ( If youd like to stand on a 8 ft square over 4 50 Gal  Drums , you MIGHT NOT want to Walk Back . Even On occasion ! )
Weighs 71 Oz . Or Did . I havnt Finished Sanding YET . Macchi weighs 57 .
Got a Dual Engined Flying Boat drawn up  , Lines not Unlike Howard Hughes 8 engined one xed with a widgeon or Goose ( They used to operate in the neigbourhood & pretend to be Santa at Christmass )
At a rat infested past its use by decaying chateau , inhabited by vermin .
But it looks a bit like the coast at the Tidal Level . :-\
The Bones of it . 16 % Airfoil Sesqui plane . Rather Low Aspect Ratio on the LOWER WINGS .
Flys like its on Rails , for some reason . Wafling along slow you  feel the better adhesion / secure lift ,
of The FLOATS . & Longitudinal Directional Stability  akin to a keel . @ say 5 Deg. Nose Up ,
gentle wing rock laterally as they search for lift . The Floats are providing say 50 % ?? at low speed .
Thisisit At Themoment .  Supermarine S6B  :( stripped back in prep for refinishing . Had It Airborne a few months back . G-51 ST 12 x 5 Top Flight .
« Last Edit: July 13, 2016, 12:02:04 PM by Matt Spencer »
Re: Flying on Water
« Reply #15 on: July 13, 2016, 11:57:53 AM »
Re: Flying on Water
« Reply #16 on: July 13, 2016, 12:27:44 PM »
We can do this LL~  I wanted to slap some pontoons on a beat up Testors Ringmaster an try it. Just don't know where to get some cheap light pontoons.
One BIG one ( little R/C ) and a leg & wee wun out the way Ea Side , on a ringpiece , Id Think . ( That Didnt come out to well ,  :-X)
 the bow wave woldnt go INTO the prop , then . Which is a consideration .A Steak knife & builders Foam , butchers brown paper , varnished .
A chap here knocked up a OS 20 max ( the 1970 ones ) R C ' widgeon ' in two hours , just FOAM , 5 - min epoxy , scrap ply . 2 minute wonder for the annual lake  meet .
if the floats solid foam , you wont get any leaks .
Elongate the sucker ,  have the front of the wing fitting the top or the windows , L E at the top windsgreen break . 60 span , two OS 25s ( 8 x 6 three bladers ? )a wheel in the hull maybe for terra firma .
NO.   NOT like THAT .
Lycomings in the ' super ' Widgeons . https://sites.google.com/a/aotea.org/don-armitage/Home/great-barrier-island-history/air--sea-transport-tofrom-great-barrier-island/air-transport/amphibians-era-1955-89
might do a slightly tider / detailed one . STEP is same as mainwheel location on Trike Gear .
« Last Edit: July 14, 2016, 01:05:28 AM by Matt Spencer »
Offline Chris Fretz
Re: Flying on Water
« Reply #17 on: July 13, 2016, 12:54:30 PM »
That a pretty cool looking airplane! I like the pontoons.
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #18 on: July 13, 2016, 12:56:13 PM »
I saw this and wile back an was surprised it's about the only video out there on this.
AMA 1104207
Advanced
Re: Flying on Water
« Reply #19 on: July 13, 2016, 01:00:37 PM »
I just started building this.
Charles
Re: Flying on Water
« Reply #20 on: July 13, 2016, 02:25:56 PM »
Nils and I still email on occasion. As I recall, he said that Magnum was an OPP and was already too heavy to be a good PA plane, so when he found out about the ROW event, he put the floats on it. What didn't help was the total weight was really high, like 6 lbs or something like that, plus the Vertical CG was terribly low, so it insisted on flying with the outboard tip high. As I recall, he had throttle control and an early type Fox Eagle .60 in it, and flew it at reduced throttle. He won the event by being a good flier, and managed both a good takeoff and landing on the water, with some level laps between.
I was at that Roseburg NW Regionals, but mostly just remember seeing PW flying (and winning) Expert PA with his second B-17 Stunter, and that it was a rainy weekend. I also met Wayne Trivin  and Rad Racer that weekend.  y1 Steve
Offline Chris Fretz
Re: Flying on Water
« Reply #21 on: July 13, 2016, 06:01:34 PM »
Charles
Are you going to fly if off water?
AMA 1104207
Advanced
Offline Jim Svitko
Re: Flying on Water
« Reply #22 on: July 13, 2016, 06:55:37 PM »
A local RC club here has float plane events.  If you have a club nearby you might ask if any of them do any such events and you might get some pointers and advice from them.
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
Re: Flying on Water
« Reply #23 on: July 13, 2016, 09:36:54 PM »
Put wings on this.
AMA 77370
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #24 on: July 13, 2016, 10:01:08 PM »
Maybe these bad boys! An extra 5.5oz  http://www.ebay.com/itm/161713085471
These are light, but the plane they are designed for is 47 inch wingspan.  I am positive a ringmaster size plane can carry them, they might just look big.
 This is definitely one to ponder.
All my float flying is from rc. Including rc helicopters! Those are fun in the water
Re: Flying on Water
« Reply #25 on: July 13, 2016, 10:24:54 PM »
A Control Line Plane is FAIRLY LIGHT . The Displacement of the Floats required Isnt a Lot . say 200 / 250 %  Toatal Volume ( Submerged . ) 300 max , to keep the Drag / weight down . With say 1 or 1 1/2 prop clearance sitting
Horizontal . For Aerobating Ive kept the floats ' in ' to the plane , so the offset isnt excessive . Ive Set the floats ' neutral ' = Nose to half ar . . Hight at rear . Sight along em , fore & Aft to guestimate the ' Zero Lift ' , and set
to Zero Incidance with the wing . If say 2 - 3 deg. Nose Up & Down they look equal ' windage ' for lift . , is my theory . Maybe Toe in rather than Toe Out . You Need STIFF 5/32 Wire . 1/8 on the Macchi 72 isnt really good enough .
This ISNT my Drawing : but ive got this Bernard HV 220 Drawn Up , maybe ST 46 Size , scale based elongated . The WING is a Dead Ringer for the BERINGER Wing , Taper Wise . ( Maybe they copied it  >:D )
for thopse of French Ancestry .  ;D Give me a yell if you cant live without building one . TheDURAL Landing Gear Legs'd be easy . F Glass Floats and youd save time long term . Building THREE Fuselages is a bit tedious ! .
Cylinder Head would hide , side on , between the inverted cylinder banks . Was ( pleasantly ) surprised there were no ' assymetric '  issues with the S6B or Macchi 72 , bar you can feel the ' lower wings '
above or below going way slow , lifting . At the old 5 seconds odd a lap , the Macchi particularly is ; in the groove ' . Dunno Why but Im Not Complaining . But the floats lines are V Clean . No Great Drag , there .
Re: Flying on Water
« Reply #26 on: July 13, 2016, 10:40:11 PM »
Done preliminary Drgs for a ' 65 ' for two .25s . C F Yacht Battens , 3/8 x 1/2 would be simple ridgid booms. a bit weighty - 1/8 wall . But V Stiff , Would Need Jig Assembly I would think .
One of the Best Looking is the 67 , Straight Wing Again . But upright Engine . WOULD the thing work / one way to find out .  :(
Only Needing an Extension Shaft Ballrace set ups stopped me Starting Building THIS , its DRAWN . But its a HYDROFOIL , 45 deg. camber on hidden wheels would be ' intresting . Could tend to go on its roof ,
so might need a dodge , there .
longish nose , would the moment give torque twist trouble . Could always chop the longness away if it did . :(
Dubbed ' The Flying Submarine ' .
Re: Flying on Water
« Reply #27 on: July 13, 2016, 10:46:02 PM »
Ive Absconded with THESE from Europe. Its NOT me .
There FOAMY Electro MC 72s for R.C. Probly the quickest way to get going , If You DO have WATER . Chuck a Bellcrank in rather than that expensive short circuitry .
One Would Think REPLACEMENT FLOATS for the Fun Fly MC72 would be available , light , and ( maybe  :P cheap ??
 :o :o :o :o A Thousand Bucks should start to cover it .  :P
HERES A CHEAP STYRO MC67 Think theres a MC 72 too .
S6B Styro ,
hrumph / L Wt PB26 Twin Flying Boat . Keeping it Simple & to esesential Ellements.  H^^
« Last Edit: July 14, 2016, 01:21:44 AM by Matt Spencer »
Re: Flying on Water
« Reply #28 on: July 14, 2016, 05:56:55 AM »
Liner,
To fly the model off water I would have to have retracts, or at least for the front wheels. Retracts add weight. There will be enough weight already with the floats and wheels.
I'm designing the wing with a symmetrical airfoil so I can get some mild stunts out of the model. I have to keep the weight down as best as possible, so, I probably won't be flying it off of water.
For those interested, here's my progress.
Charles
Re: Flying on Water
« Reply #29 on: July 14, 2016, 07:29:32 AM »
Itll be intresting to see how it goes .
Think its easiest to carve say a pine float , 3/32 undersize , and mould the skins . Or just use plastic , particularly if you have a vacuforer .
If theres a 5 mm lip on the upper edge of the bottoms , glued inside the uppers sides , theyed be quite ridgid and weigh naff all .
a couple of formers to pick up Alumn. legs ?? ( that connection needs to be secure )
Fibreglass over a plug maybe better . If your really cunning Alloy U brackets for the wheels , could be screwed on , thus removable .
A tube 7 C clip in a groove in the wire , at front .
On Grass the suckers usually slide . Less So clockwise, its trying to pull outward . I think Counter Clock ( Normal ) the in turn ( tourque )
would have it sliding no worries . Mine are normally flown ion grass . Grass or Water , if you drop it from 1 inch up , its sliding fwd already.
Look at the old 15 Deg Wheel bit , for ' bouyancy ' as the force angle / CG on water , if you do try it , you dont want it driving the noses under .
Floats built as an assembly , jigged when fitting the legs , if That bolted on the fuse as a assembly , would be self aligning .
To soft in the legs and youve good big ' surfboards ' under there twisting away trying to steer the plane .
Dimensions akin to Old Time Stunt should work . Be intresting with the ; big ; floats theres a fair bit of LIFT in them , so conventional ' sums '
arnt allowing for that ' lifting area ' as wings , in the Oz / Sq Ft bit . If you dont go filling it up with concrette , it should work good .
You COULD just fit one wheel Ea Side , up inside the floats . Under the leading edge .
If they were hard team race disc wheels , a moulded cover up in it , a few brass tubes & a Press In axle would have them fittable or removable ,
Theyd only need to stick out 1/4 in . Ive Flown over smooth concrette , Spruce Runners on the keels , So you dont REALLY need wheels .
 H^^
Dunno What Payload that thing carries , but its got a bit of freeboard . Has to have reseve capacity for storms & suchlike .
Your Probly better building a DC3 on floats .  8) :## VD~
( Just Kidding about the DC3 !  ;D LL~ S?P)
Pye korrie . ''
The Early snow commanders had short noses and great round engines , The nose is long as the Turbo Prop weighs nothing , so watch the weight forward there ,
A exhaust elbow with the muffler aft of the L E might be usefull . It doesnt look like a Fox or OS Max 35 , theyre 6 ounces .
« Last Edit: July 14, 2016, 07:58:22 AM by Matt Spencer »
Re: Flying on Water
« Reply #30 on: July 14, 2016, 08:43:17 AM »
yep,. the Snow S-2,(commander) became the Rockwell Thrush and Ayre Thrush
Leland Snow sold the rights and in doing so signed a no compete for a period of time, either 7 or 10 years, not toally sure. Then he produced the Air Tractor.
Now he has expanded the original AT301, 300 gallon, radial powered, and now it has become th AT-802 which also becomes the Fire Boss on floats. I am not sure that the yellow AT-802 isnt just the prototype of the Fire Boss.
interesting note, he also produced a version he marketed to smaller countries for civil defense use armed with missiles and such
Re: Flying on Water
« Reply #31 on: July 14, 2016, 08:54:39 AM »
Just because,,
here is a link to the company I used to work for, I designed the conversion and helped get the conversion approved and the PMA in place. which originally was for a Walter M601 Turboprop installation. The Walter was mounted on the Let 410 commuter aircraft and is Czechoslovakian in origin.
Later they went to PT-6 for various reasons.
anyway, it is prettier than the FActory PT-6 installation IMHO
http://cascadeaircraftconversions.com/
the Parent compnay here
http://www.airtractor.com/
and the most interesting aspect,, the close air support version here
http://www.802u.com/
Offline Chris Fretz
Re: Flying on Water
« Reply #32 on: July 18, 2016, 07:34:12 AM »
Any scientific location as to where you mount the floats besides on the bottom of the plane? Any relationship to the CG of the airplane?
AMA 1104207
Advanced
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #33 on: July 18, 2016, 08:33:29 AM »
Just because,,
Thanks for the links Mark. My favorite aircraft for sure.
Offline Chris Fretz
Re: Flying on Water
« Reply #34 on: July 19, 2016, 04:25:26 PM »
HA! What do you think of the AquaRing? Maybe the floats are a little too far forward like Matt suggested. I have no Idea but its looking pretty cool.
AMA 1104207
Advanced
Re: Flying on Water
« Reply #35 on: July 19, 2016, 04:31:59 PM »
AFAIK -- and I've never tried it on anything but rubber-power -- the step should be a bit behind the CG.  For a 40-sized plane the dimension I remember is 1/4 or 1/2 inch.  Dunno why, although it probably has to do with stability when it's up on the step.
Re: Flying on Water
« Reply #36 on: July 19, 2016, 04:46:20 PM »
pretty much what Tim said,
the step relates to the CG, normally the top of the float is parallel to the line of flight ( because most floats are designed so they can be rigged that way
Offline Chris Fretz
Re: Flying on Water
« Reply #37 on: July 19, 2016, 05:05:10 PM »
The pontoon step is pretty close to the spare in the wing,  sounds like a winner to me.  You sure have a wide range of  knowledge Tim!
AMA 1104207
Advanced
Re: Flying on Water
« Reply #38 on: July 19, 2016, 05:11:07 PM »
Like Fibber McGee's closet.
Offline Chris Fretz
Re: Flying on Water
« Reply #39 on: July 20, 2016, 06:46:34 PM »
By the way what is "AFAIK"?
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #40 on: July 20, 2016, 06:49:21 PM »
Ready to give the AquaMaster a try! Hopefully I'll give it a try on Saturday. It clocked in at 37oz.
AMA 1104207
Advanced
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #41 on: July 20, 2016, 06:51:48 PM »
Omg I'm jealous! That's awesome!
Offline Chris Fretz
Re: Flying on Water
« Reply #42 on: July 20, 2016, 07:05:56 PM »
 ;D I'm checking this off the bucket list one way or another #^
AMA 1104207
Advanced
Online Paul Taylor
Re: Flying on Water
« Reply #43 on: July 20, 2016, 07:36:45 PM »
Re: Flying on Water
« Reply #44 on: July 20, 2016, 07:56:57 PM »
Thanks Rootbeard , I couldnt find that one again on Utube , with 800 Windy Videos . :o
Sight Behind and left , for three strides aft ! . If Static Release . Dropping From a inch or two up ( aimed striaght )
seems to be instantly on the step & running true , so doesnt involve footwork .
The Kiwi Widgeons came over with a un ' bulliten ' Step posn . Was Moved Aft 9 in. or suchlike . On Occasion theyed
try the pirruette waltze on landing . Years Later someone realised the problem & the hulls were updated .
The STEP Posn. is a bit like the ' Rotation ' point . To Far Aft & the nose is glued down , but to short all the keels Fwd of the C.G.
Looking at it ' on the step ' , thwe rear of the keels in , only . That is about at the C.G.
Watch It with a Static Release , The Nose May Try'n Turn In under the acceleration . So Like a erant 2 Wheel Job - you may need to go aft
for line tension .Await the Flight Report . Looking GOOD .
Offline Chris Fretz
Re: Flying on Water
« Reply #45 on: July 21, 2016, 07:47:39 AM »
I bet a water crash is epic looking!
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #46 on: July 21, 2016, 10:06:13 AM »
So your saying the floats may be a little far forward, and on takeoff it might turn in at me?
AMA 1104207
Advanced
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #47 on: July 21, 2016, 04:35:26 PM »
Kinda like a speed plane wants to turn in on you, you have to back up quick and keep tension on the lines.  With the prop spinning the direction it does and the fact that the pontoons will be stuck to the water, the plane will want to turn it's nose to you. I don't know the actual terms to use,  I just know how it feels. I also know how silly I feel when I get two spin outs in a row in a speed contest. ....  ~^
Offline Chris Fretz
Re: Flying on Water
« Reply #48 on: July 21, 2016, 04:44:18 PM »
Makes sense! Is there any way to stop that if it happens?  Might be a good youtube video you guys see on Sunday ;D
AMA 1104207
Advanced
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #49 on: July 21, 2016, 04:56:01 PM »
Keep in mind,  I've flown plenty of float rc planes and helis, but no cl.... so if someone intelligent chimes in (like Tim or mark) that would be the way to go
I would fix a small slightly adjustable rudder on the right pontoon and add some pontoon offset rudder. Then,  get it going,  and off the water as soon as it is safe to do so.
So lots of horse power!  Lol
