  • July 17, 2025, 09:40:13 PM
Author Topic: Veco Chief (Dumas) landing gear wire diameter??  (Read 1148 times)
Offline Dennis Holler
« on: May 03, 2014, 12:35:18 PM »
I've been working on this old Chief kit and the landing gear wire that is in the kit is about 3/32th's diameter.  Would I be better off bending a gear out of 1/8" music wire?  Mind you I'm pretty hard on the  equipment  HB~> HB~> HB~> HB~>   LL~ LL~ LL~ LL~ LL~
I've started plenty...would be nice to finish something!!!
Re: Veco Chief (Dumas) landing gear wire diameter??
« Reply #1 on: May 03, 2014, 01:11:02 PM »
Hi Dennis,
I would go with the 1/8th" wire.  y1
 BIG Bear
RNMM/AMM
Offline bob whitney
« Reply #2 on: May 03, 2014, 01:50:35 PM »
The Chief would look good with a carbon gear
rad racer
« Reply #3 on: May 03, 2014, 03:40:58 PM »
Thanks bill, I'll have to track some down on Monday at lunch or something as my "close" supply of K&S stuff was out of the 1/8" wire  '' .   There are 3 or 4 places I can check on Monday though and hope to get lucky   LL~ LL~ LL~
Bob,  You may have something there, I might have to try that on a future build, Thanks!  H^^
Offline 55chevr
« Reply #4 on: May 03, 2014, 03:43:00 PM »
McMaster-Carr.
Joe Daly
Offline larry richards
« Reply #5 on: May 03, 2014, 11:33:37 PM »
The original wire gear was 1/8th in the kits.  If you would like, I still have a couple of aluminum landing gears left over from the Chief kits that I use to make.  Let me know.  I sell them at $8.00 plus priority mail.  Larry / Richardskits  ;)
« Reply #6 on: May 04, 2014, 08:04:03 AM »
I hear Sparky has a great carbon gear that would work for your Chief build.    Now don't forget the pictures. H^^
