  • June 17, 2025, 03:06:25 AM
Author Topic: Fuel consumption- ounces per minute?  (Read 1430 times)
Offline jeffindayton
  • AMA 166779
« on: June 15, 2006, 08:59:26 AM »
did not see any thing related to fuel burn times, thought maybe we could post some averages with this type format.
Ounces of fuel
run time
percentage nitro
engine size
I ask this as a newbee to c/l and would like to build a tin tank close to 8 minute run time.  ???
Dayton, OHIO USA
Smooth Flying...not yet
Jeff Huntsman
Offline Jim Thomerson
Re: Fuel consumption- ounces per minute?
« Reply #1 on: June 15, 2006, 09:10:48 AM »
With a Fox stunt 35, 10% nitro 25% castor Sig Champion fuel, 4 ounces will get you through a stunt pattern with @ 10 extra laps on a cool, dry, high pressure day.  On a really hot, wet, low pressure day, it may take only 3 oz.  So weather is a factor if you are going to have to run the engine to get maximum power.  Flying a pattern takes around 6 minutes, I suppose.
Offline L0U CRANE
« Reply #2 on: June 16, 2006, 05:09:57 PM »
Jeff,
Go with Jim Thomerson's guide for starters. You may find some more differences due to altitude, as well. Nitro and oil % can also affect time per ounce, and I don't know of a rule of thumb for these that will work for all engines and conditions.
Run-time vs ounces fuel is not usually as critical for stunt fliers. Usually the tanks are a bit too big for the thirstiest conditions you'll face, and you limit run-time by underfilling it. We only need enough to complete a pattern plus several laps, and not so much we run over-time. Pretty loose limits.
Good sized syringes (e.g., 5 fl oz) let you fill the tank, then draw a measured amount back out to get a certain amount in there. Trying to presume it is empty, and fill a measured amount, is not as sure.
\BEST\LOU
« Reply #3 on: June 17, 2006, 01:25:26 PM »
As several have stated you have to take a lot of things into consideration.  The type /make of engine.  The fuel, plug and prop.  And of all things the airplane design.  Old Time for me and the Dragon is 2 and 3/4 ounces of fuel.  The Falcon 35 with OS FP-35 is 3 and 3/4 ounces.  The DoodleBug with OS FP-40 is 4 and 1/2 ounces.  The Accentor with the RO-Jett BSRE-40 is a little less than 4 ounces.  Now the ARF Oriental with 4 ounce tank and Brodak 40 will not get me thru the 4 leaf clover.  All above run on 10% nitro.  The RO-Jett is being run on pure synthetic oil fuel by Power Master.  Now you see what we mean when we say it depends on a lot of things.  DOC Holliday
Offline RC Storick
« Reply #4 on: June 17, 2006, 11:29:14 PM »
PA .61 1.1 oz per min. PA.75  1.6 oz per min 10% on both.
