  • July 06, 2025, 05:11:45 AM
Author Topic: kbs diamond coat  (Read 822 times)
Offline Bootlegger
kbs diamond coat
« on: September 17, 2014, 07:18:32 AM »
 Guy's I don't remember where I read about spraying this stuff, but if you sprayed it tell me what you used for thinner, how much you thinned it and what gun (hvlp or syphon) and what pressure that you sprayed at, plus any other suggestions that you have in regards to using this paint.
      Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline David_Stack
Re: kbs diamond coat
« Reply #1 on: September 17, 2014, 10:48:59 AM »
Good Afternoon Gil;
  Take a read through this thread: http://stunthanger.com/smf/index.php/topic,31735.0.html.  Looks like most were brushing it on, but there is at least one post from a builder who used an airbrush to spray it.
r/
Offline Bootlegger
« Reply #2 on: September 17, 2014, 10:59:32 AM »
 Thank you Sir, I found the posting after I had asked.  Again thanks...
Gil Causey
AMA# 6964
