  • June 18, 2025, 06:32:34 AM
Author Topic: ST parts ID help  (Read 1141 times)
Offline Steve_Pollock
ST parts ID help
« on: January 04, 2016, 07:32:05 PM »
I have two NIP ST heads.  One is marked 1341, fits into about a 20.5mm cylinder bore, head bolt spacing diameter about 29mm across the head, and it has a cut for a baffle.  May be a G21/40 head.  The other is marked 1550, fits into about a 20mm cylinder bore, head bolt spacing diameter is also about 29mm, and does NOT have a baffle slot.  May be a G21/35 combat head.  These part numbers are earlier than my reference material.  Since they are in original packaging I did not remove them to make exact measurements.  Thank you in advance for your help.
Offline Phil Spillman
Re: ST parts ID help
« Reply #1 on: January 04, 2016, 08:43:24 PM »
 ST had a plain bearing .35 billed as a Stunt Engine back in the 70's and 80's. It was also sold as an RC engine both varieties had plain bearings, not ball bearings. The Carrier community had a rule for awhile that only PB engines would be eligible for Profile Planes. after I bought one of these engines they changed their rules so my engine wasn't quite as good as I had wanted it to be! This engine did have a baffled piston and so your grooved head could be for this variety of the "C" PB group. They also had a Schneurle PB design which was great for Combat, Slo Rat, and Sport flying in general. This model didn't have a baffled piston as it wasn't needed! These were really fine running machines.
I've sold off or given away most if not all of my older ST's save for the vaunted G-21 .46's which still make a fine running Stunt engine!
Hope these ramblings were of some help to you!
Phil Spillman
Phil Spillman
« Reply #2 on: January 04, 2016, 09:47:35 PM »
Thank you, Phil -- it does help.  I just don't have a parts list for the ST .35 combat and ST .35 stunt engines.  I have a bunch of parts, including ST parts, that I'm getting ready to sell, but I'd like to know what engines they fit before I list them.  The fact that Supertigre changed parts numbering systems several times doesn't help. either!
Offline Roger Vizioli
  • CLiner
« Reply #3 on: January 04, 2016, 10:20:02 PM »
Steve,
check your e-mail.
Roger Vizioli
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Bob Matiska
« Reply #4 on: January 05, 2016, 04:40:04 PM »
My 1968 World Engines catalog doesn't list either part number. The 1974-75 edition, however,  shows part number 1550 as the head for both the G21/35 ball bearing engine and the plain bearing 35 Combat. The number 1341 doesn't come up in either catalog. An engine test of the G21/40 RC at Sceptre Flight lists the bore of that engine at 20.4 mm, so the 1341 head is indeed most likely from an ST 40.
Good luck,
Bob in NEPA
AMA 56267
