  • July 18, 2025, 03:44:39 AM
Author Topic: Flying on Water  (Read 14326 times)
Re: Flying on Water
« Reply #50 on: July 22, 2016, 12:30:17 AM »
It l;ooks pretty much spot on , with the huge floats there theres likely No Problem .
IF accelerating from ' sunk ' the prop tourque would further sink the Inner . A Wee Shove , or Dropping It, onto the water ( motor Running )
saves its bewiderment and myrid of forces ( Lines , Float Drag , tourque , acceleration reaction etc )
But Still , I Made Mine Counter Clock , so if flown from a RAFT , I wouldnt walk of the back of it , on take off .
Id Done a Morley T Bolt with floats , that sat into the wavelets and wind , bogged down ( underpowered )
I walked a fair way back up the beach gently keeping the tension on the lines . HENCE the current ' Lines on the Other Wing ' set up .
The Tourque can actually stuff up flying on grass , as they want to turn out , thus the keel scrubs & sticks .Unless Given a SHOVE .
I Think your only look out will be keeping the lines OUT OF THE WATER . maybe. Speed Flyers Handle way up , Maybe .
Your FLOATS are TWICE the Bouyanct of mine , so youll be out of the ' edge of the margins ' , where on landing
the lines can weight the inner float of the MC72 under  & put a tip in the water . Then the WET lines are heavier ( than dry )
so it dosnt want to get back on an even keel . WHICK IS WHY IT NOW HAS BIGGER FLOATS ( 40 % more bouyancey )
But as it was ACE  for F2B , if its not gonna go like it  did atmosphereically (  S?P) the skinny floats will be remade & fitted .
SO ,
A , Keep The LINES DRY .
B. Give it a Shove , or drop it from 1 or 2 in above water - at least till you see ' how she goes '.
LANDING should show it all above board , and shipshape .What Happens is the WETTED AREA of the FLOATS has A LOT of ' STICTION '
untill its ' On The Step ' . So a drop or shove gets it out of the wallow , straight off .
Lookie Here , Twin Fans ( Hulls big enough for one HUGE One ) Symetrical Airfoil , Stab Trims , so is almost ' full Moving '.
The Say no troubles with snout drinking on it . One or two hit a log, holed and SUNK . :(
If youve seen the massive Russian Albatross Jet flying Boat , it sits way low - Massive power gets it moving like a ship .
at some speed , the thing surges up like a cork - acceleartes like blazes , with the reduce of drag ( Hydrodynamic ) ,
rotaes and goes up like a 747 , Dripping Gallons .
The 72 Sheds Water effusively , clearing the tide . touch & Go's - the ' Stiction ' gets it cutting the water , and ' in a groove 'in it .
Needs a distinct ' pull up ' to get the turn ( up ) to lift out . ON THE NARROW FLOATS . it doing a fair clip on the water ,
the rotation slows it and it holds nose up a way , gently dropping the nose ( After a Pause * ) it accelerates to flying hight ( 5-6 ft )
Gets You Wishing You Had a THROTTLE .
* the S6 full size , Full Up . ( stick in the stomach ) was held . AND AFTER TAKEOFF .If Realeased or eased it went in , Drowning one of em .
But THAT is on a high loading marginal bouyancey sucker . Worth Noting , but largly irrelevant , as your way out of those ' margins .
I should think youd have no bother . But The T Bolt did a few wingovers into the tide , and flown on Half , tide upwind Wingovered into terra firma
Lines Slack .
So to make a long story SHORT . DONT TAKE OFF INTO THE WIND ! ;D
Take  your camera & maybe a Video , if you have .
( Dropping the plane from under six inches,  Un Going , will show you its bouyancey & Sit . Again with lines & a Bod @ the Handle , Any Differance .
MAYBE Nail On extra tip weight . What We NEED is a Submerged by say 6 in. wharf / walkway . The we can do the ' walk on water ' trip . S?P)
Offline Chris Fretz
Re: Flying on Water
« Reply #51 on: July 24, 2016, 08:17:35 PM »
Well fellas I did it! Went pretty good to, the floats do make it fly a bit sluggish though. Maybe she needs a 40 instead of a 35. I got loops out of it an 8s some sloppy square loops. It was fun though!
Formerly known as #Liner
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #52 on: July 24, 2016, 08:33:43 PM »
Another view of the same video.  Ohhh yeah I tried a touch and go wile I was at it,  probably not a smart idea but it kept going.  Sure did slow down a lot though.
AMA 1104207
Advanced
Re: Flying on Water
« Reply #53 on: July 25, 2016, 11:16:45 AM »
Watching you have fun, it didn't look sluggish to this old man.   What length line? H^^
Offline Dane Martin
  • heli pilot BHOR
Re: Flying on Water
« Reply #54 on: July 25, 2016, 11:36:36 AM »
Just so you know Chris, your my new hero!
Offline Chris Fretz
Re: Flying on Water
« Reply #55 on: July 25, 2016, 01:20:49 PM »
58ft lines. Think the floats make a big air brake.
That was an epic time  #^
AMA 1104207
Advanced
Re: Flying on Water
« Reply #56 on: July 25, 2016, 04:45:32 PM »
Oooooooooooh My Gosh!
The "KING" of, "Flying "off" Water."
Great job with the camera. Absolutely inspiring.
Outstanding!
You are my hero also.
King Liner!!
Charles
Offline Chris Fretz
Re: Flying on Water
« Reply #57 on: July 25, 2016, 06:53:05 PM »
Outstanding!
King Liner!!
Charles
LL~ Thank you but I'm no King I just gave something different a try! Ha Ha I still crash with the best of them.
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #58 on: July 25, 2016, 07:26:53 PM »
Second flight...
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #59 on: July 25, 2016, 07:30:31 PM »
Let my dad give it a try, I just forgot to tell him to move back after take off to the big safe rock. I clipped this tree myself on the first try.
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #60 on: July 25, 2016, 07:49:02 PM »
I gave the AquaMaster one final flight, it was a disaster from the take off. Some reason it bounced out an in on take off, lines went slack an I never got a chance to move away from the tree that kept trying to jump in front of the airplane. I picked up a pretty big branch that didn't let go of the airplane, it hitched a ride an killed the aerodynamic Ringmaster. All in all I had a blast!
AMA 1104207
Advanced
Re: Flying on Water
« Reply #61 on: July 25, 2016, 08:08:09 PM »
"King" Liner,
You need a bigger pond.
I just thought of something. The water is moving at a good speed, so it must be cold as hell.
Offline Chris Fretz
Re: Flying on Water
« Reply #62 on: July 25, 2016, 08:13:32 PM »
"King" Liner,
It was humid an sooooooooo hot that day the water felt good. It's not usually too cold,  you can swim in it.
AMA 1104207
Advanced
Offline Chris Fretz
Re: Flying on Water
« Reply #63 on: July 25, 2016, 08:15:16 PM »
I don't really know what I would of done if a kayaker came by at that moment!  An some how some way I'm sure I broke some law doing that.
AMA 1104207
Advanced
Re: Flying on Water
« Reply #64 on: July 25, 2016, 10:34:17 PM »
School of Hard knocks !
Just as well you missed the Tidal Waves .  VD~ LL~
good Camera work . Looked to fly good . New Class for C/L Stunt . ! Can repair it for the next rainy Ringmaster Day , they fly good on wet grass & snow .
Thanks for posting the Videos .
The Extra Drag in nose up or down pitch with the floats , and acceleration withem ' neutral ' to the flightpath is evident ( Three Fuses )
sortta indicates how much that drag is the Fuse rather than the wing , on conventional ( air ) ships . Being a profile with the floats .
Sort of ' edgeing ' or flying the turn stops it . Or you can look at them as another ' trim ' consideration .
 Certainly didnt look to curtail its aerobatic ability .
 H^^
Any Alligators out there .   :) ;D
« Last Edit: July 25, 2016, 10:59:35 PM by Matt Spencer »
Re: Flying on Water
« Reply #65 on: July 26, 2016, 09:21:29 AM »
Looks like it will fly again.   May have to go to shorter lines.  I hope you did check every thing before that last flight.  Any way that water has to be cooler than a pave lot this time of year.  As Matt says, wet grass or snow will work.  We did that with the RC floats planes when I played with RC. H^^
Offline Chris Fretz
Re: Flying on Water
« Reply #66 on: July 26, 2016, 10:10:38 AM »
That Ringmaster took some abuse. Hitting trees an water seemed to absorb most of it, the wing never broke out of the fuselage. I did use some CA on it after the first crash. Mostly just the one float started falling apart, and some monokote holes. Think I might try my OS Max-H 40S  in it next  ;D
AMA 1104207
Advanced
Re: Flying on Water
« Reply #67 on: July 26, 2016, 11:04:15 PM »
Though the ' defoliage ' was pretty good . But Vertically into rock , 3 in. of water isnt going to slow it down , a lot .
My Blankety 40S in the 72 is a bit wallowey on a 11x6 , Fitted a 11x5 thinned . The Master Black 11x5 worked pretty good .
Thinking the tide / current just caught it and pushed er in , on THAT take off . Heavy Rain and Flooded Fields give a good ' pond ' .  ;) H^^
Re: Flying on Water
« Reply #68 on: July 26, 2016, 11:12:57 PM »
If youve got a FP or LA it might be kinder to the Venerable 40S to thermal shock something else , in the dunkings .  :-\
