  • July 11, 2025, 01:13:06 PM
Author Topic: K2R available, and a substitute!  (Read 2827 times)
Offline Larry Renger
« on: June 15, 2009, 11:53:26 PM »
I recently found that I was out of K2R oil remeover, and hunted around for a source.  It turns out, that in the LA area, Ace Hardware seems to be the only convenient supplier.  While there, cleaning out their stock, I noticed that there is also a "Goddard" spray spot remover.  I bought a can, and it works great!  How nice to have an alternative!!!   #^
Offline Robert McHam
Re: K2R available, and a substitute!
« Reply #1 on: June 16, 2009, 08:19:41 AM »
Larry, that is good to know. Is the Goddard close in price to the K2R?
Robert
« Reply #2 on: June 16, 2009, 09:09:50 AM »
About the same.
« Reply #3 on: June 16, 2009, 09:50:04 AM »
I may have found another possibility with a much better value!
16 ounce can as opposed to the 5 or 6 offered by the K2R and Goddard's and for $4.99 per can!
The description sounds just like the other products.
http://www.universalsewing.com/tek9.asp?pg=search&mode=results&searchby=Products&srch=&usssearchby=header&usscriteria=398.1
What do you fellas think?
Robert
