  • July 13, 2025, 03:50:20 AM
Author Topic: Evo 60  (Read 1197 times)
Offline Bootlegger
Evo 60
« on: December 05, 2014, 08:23:50 AM »
 Guy's I am looking for some venturi "O" rings for the Evo 60 engine.
  They are fairly thin approx 1/16" thick, so any help/suggestions will be appreciated..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bill Hummel
Re: Evo 60
« Reply #1 on: December 05, 2014, 11:29:19 AM »
Hi, Gil, I get my small O rings from Jim Lee; he has 8 mm and 10 mm diameter ones that are really "thin", have
never found any around here as good as Jim's!
ama 72090
Re: Evo 60
« Reply #2 on: December 05, 2014, 11:39:13 AM »
Hi Gil,
McMaster-Carr is where I get O-Rings but thier website seems to be down right now...not sure why.
Grainger is another likely supplier.  Order o-ring by I.D. and cross section...you want ideally a few thousanths smaller than the venturi barrel that it fits on...they will in fact stretch about 10% with no deleterious effect!
Ace Hardware also sells small kits with an assortment of o-rings and you could probably find what you need in the kit but of course you then have about 50 other o-rings to find a home for... ??? ::)
Offline Andrew Saunders
  • 2013 Nats
Re: Evo 60
« Reply #3 on: December 05, 2014, 08:24:04 PM »
Horizon Hobby will carry them for that engine also.
Re: Evo 60
« Reply #4 on: December 06, 2014, 09:38:26 AM »
Got my O rings for Jim's fuel injector at the local O'Reilly's auto parts.
