  • June 19, 2025, 06:03:13 PM
Author Topic: hot box  (Read 1463 times)
Offline Bootlegger
hot box
« on: January 14, 2013, 04:47:35 PM »
  I am looking to build a box of wood and styrofoam to use for drying l/e molding and other projects.
  My intenton is to use light bulbs as heaters.
  Does any one have some better ideas?
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: hot box
« Reply #1 on: January 14, 2013, 04:59:32 PM »
Yea. Move to the sunshine state.  LL~
Just having some fun.
Sounds like it should work. Might want to find a thermostat off a old BBQ grill to get it to the right temp.
Offline Lynn Weedman
  • x47weed (Lynn Weedman)
Re: hot box
« Reply #2 on: January 14, 2013, 04:59:41 PM »
You could use a old upright freezer (22cub ft) line it with sheet metal and light fictures and a thermo coupling (temp guage) and you are in business, you could even add a reostat to regulate the temp and a exhaust fan if you want to do it all the way.
I guess a chest freezer would work also......
Lynn Weedman
Lynn Weedman
Re: hot box
« Reply #3 on: January 14, 2013, 05:56:50 PM »
No.  That's what I do, but with cardboard instead of wood and 2" of foam on the walls.  (I guess you could skip the cardboard, too.)  It works dandy.  A dimmer works as a throttle.  A 40W bulb is adequate for mine.  I use a digital thermometer to keep track of temperature in the box without having to open it.
Offline don Burke
Re: hot box
« Reply #4 on: January 14, 2013, 06:02:16 PM »
Footlocker with a 40W bulb worked great for one of my kids for marijuana cultivation at the foot his bed.  That is until Mom touched it one day!
don Burke AMA 843
Menifee, CA
Offline Bill Heher
  • Fix-it
Re: hot box
« Reply #5 on: January 14, 2013, 08:18:43 PM »
a crock pot base would have a temp controlled heating unit, that in a 2$ sheet of foam to build your "Igloo" out of to put over it and Presto- Hot Box.
Bill Heher
If it's broke Fix-it
steven yampolsky
Re: hot box
« Reply #6 on: January 14, 2013, 08:46:04 PM »
Does it take a long time to dry? I live near the coast and humidity is definitely an issue but molded balsa typically dries on its own in 6-8 hours. I'm sure that if I lived in Arizona, it would probably dry in one hour and be completely petrified in two.
Is this not adequate for you needs?
Offline David_Stack
Re: hot box
« Reply #7 on: January 15, 2013, 06:45:58 AM »
Working with composites is common-place in the R/C sailplane community.  Resins of choice are frequently those which require a post-cure to achieve maximum rated strength, so hot boxes are a known commodity.
Take a look here to see one constructed by a flier/builder.  May be overkill for your needs, but could likely be 'scaled down'
http://www.rcgroups.com/forums/showthread.php?t=1138304&highlight=hot+box
r/
