General control line discussion => Open Forum => Topic started by: Bootlegger on January 14, 2013, 04:47:35 PM
Title: hot box
Post by: Bootlegger on January 14, 2013, 04:47:35 PM
  I am looking to build a box of wood and styrofoam to use for drying l/e molding and other projects.
  My intenton is to use light bulbs as heaters.
  Does any one have some better ideas?
Title: Re: hot box
Post by: Paul Taylor on January 14, 2013, 04:59:32 PM
Yea. Move to the sunshine state.  LL~
Just having some fun.
Sounds like it should work. Might want to find a thermostat off a old BBQ grill to get it to the right temp.
Title: Re: hot box
Post by: Lynn Weedman on January 14, 2013, 04:59:41 PM
You could use a old upright freezer (22cub ft) line it with sheet metal and light fictures and a thermo coupling (temp guage) and you are in business, you could even add a reostat to regulate the temp and a exhaust fan if you want to do it all the way.
I guess a chest freezer would work also......
Lynn Weedman
Title: Re: hot box
Post by: Howard Rush on January 14, 2013, 05:56:50 PM
No.  That's what I do, but with cardboard instead of wood and 2" of foam on the walls.  (I guess you could skip the cardboard, too.)  It works dandy.  A dimmer works as a throttle.  A 40W bulb is adequate for mine.  I use a digital thermometer to keep track of temperature in the box without having to open it.
Title: Re: hot box
Post by: don Burke on January 14, 2013, 06:02:16 PM
Footlocker with a 40W bulb worked great for one of my kids for marijuana cultivation at the foot his bed.  That is until Mom touched it one day!
Title: Re: hot box
Post by: Bill Heher on January 14, 2013, 08:18:43 PM
a crock pot base would have a temp controlled heating unit, that in a 2$ sheet of foam to build your "Igloo" out of to put over it and Presto- Hot Box.
Title: Re: hot box
Post by: steven yampolsky on January 14, 2013, 08:46:04 PM
Does it take a long time to dry? I live near the coast and humidity is definitely an issue but molded balsa typically dries on its own in 6-8 hours. I'm sure that if I lived in Arizona, it would probably dry in one hour and be completely petrified in two.
Is this not adequate for you needs?
Title: Re: hot box
Post by: David_Stack on January 15, 2013, 06:45:58 AM
Working with composites is common-place in the R/C sailplane community.  Resins of choice are frequently those which require a post-cure to achieve maximum rated strength, so hot boxes are a known commodity.
Take a look here to see one constructed by a flier/builder.  May be overkill for your needs, but could likely be 'scaled down'
http://www.rcgroups.com/forums/showthread.php?t=1138304&highlight=hot+box
r/
