The 25LA is still available and works straight out of the box like a 20FP. Once it gets some run time it should make it on 3 oz (although I am sure we could get more fuel in the airplane with a custom tank).
What? You of all people!! I've run several LA25's and they typically use about 3.5 oz of fuel for the modern pattern even here in Tucson...Hot and High...
Of course I won't disagre with what you said, but my FP20 is more consistent, at least as powerful and uses a little less than 3 oz of 10% nitro fuel with 22% oil for a 6.5 minute run.
I also agree that a larger tank even as much as 4+oz could be fashioned to fit in the Continental...however the FP20 is more fun and runs really sweet!
I built mine fom an FP25 case and crank with the FP20 sleeve, piston, and head. It's now going in a Feno!
Randy C.
