General control line discussion => Open Forum => Topic started by: steve bittner on August 11, 2013, 07:46:44 PM
Title: Engine recommendation needed
Post by: steve bittner on August 11, 2013, 07:46:44 PM
Looking for recommendations for a 25 size engine to use for a debolt continental. Has 40 wing span, only has room for 3oz  tank to get thru a classic pattern. Asking to much?
Title: Re: Engine recommendation needed
Post by: Steve Helmick on August 11, 2013, 07:57:49 PM
OS .25LA would do it fine, as would a Brodak .25. Personally, I'd go with the OS, but I'd also spend the extra $ to get the aluminum backplate and a real needle valve assembly. I don't know which would cost less after the upgrades of the OS.  H^^ Steve
Post by: Randy Cuberly on August 12, 2013, 12:30:56 AM
I hate do this but I must...
While the previous recommendations were good I have to make one here that I feel is better.
It is a little more difficult to find but there are some around...OK...
The ideal engine for this airplane, since it is relismall and builds very light with a little care is an OS FP20 with the Brett Buck setup.  Just search the foum for Brett Buck FP20.
It doesn't get any better than this.
Post by: Brett Buck on August 12, 2013, 01:25:20 AM
  The 25LA is still available and works straight out of the box like a 20FP. Once it gets some run time it should make it on 3 oz (although I am sure we could get more fuel in the airplane with a custom tank).
Post by: Randy Cuberly on August 12, 2013, 02:17:54 AM
What?  You of all people!!  I've run several LA25's and they typically use about 3.5 oz of fuel for the modern pattern even here in Tucson...Hot and High...
Of course I won't disagre with what you said, but my FP20 is more consistent, at least as powerful and uses a little less than 3 oz of 10% nitro fuel with 22% oil for a 6.5 minute run.
I also agree that a larger tank even as much as 4+oz could be fashioned to fit in the Continental...however the FP20 is more fun and runs really sweet!
I built mine fom an FP25 case and crank with the FP20 sleeve, piston, and head.  It's now going in a Feno!
Randy C.
Post by: EddyR on August 12, 2013, 05:39:39 AM
The last one I built I cut a notch into the leading edge. I flew it with a Fox 19 and later with a Fox 29. It is a very quick turning plane ,very much like a Flight Streak.
Post by: MarcusCordeiro on August 14, 2013, 09:26:02 AM
You could try the Enya 25SS,, great little engine!!!
Marcus
